What is the best gasket to use . #1119926
11/23/11 06:27 PM
11/23/11 06:27 PM
Enfield, Ct
Moe Offline OP
Moe  Offline OP
Enfield, Ct
On a Milodon 7Q drain oil drain plug? 1/2-20 in.
Not that Poor Fit Nylon gasket?
Re: What is the best gasket to use . [Re: Moe] #1119927
11/23/11 06:47 PM
11/23/11 06:47 PM
That metal impregnated fiber type that's used for ex gaskets works for me with some gasket cement
Re: What is the best gasket to use . [Re: RapidRobert] #1119928
11/23/11 06:53 PM
11/23/11 06:53 PM
scratchnfotraction Offline
I had 2 different size nylon ones in my fel-pro full gasket set
you can get a tighter fitting one at Napa
you could even try a soft copper oil plug washer
have you checked with milodon?
Re: What is the best gasket to use . [Re: Moe] #1119929
11/23/11 06:58 PM
11/23/11 06:58 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Use a soft copper washer you can get them at any of the fashion performance suppliers like vatozone , advanced or pep boys ...
