Re: Small block R3 block
[Re: jg309]
#1119787
11/23/11 06:17 PM
11/23/11 06:17 PM
Posts: 3,397 Pa
Hot 340
Pa
get ahould ryan @ shady dell speed shop & he can tell, about the only thing i can tell is look at the front of block if the water holes are round its a tall deck,half moon shape its short deck, check cam brg. holes if all are the same its roller brg. if steped(different sizes)its regular cam brg., ryans # is 8143088058
My water holes are half moon shaped and its a tall deck.
[Re: Hot 340]
#1119789
11/24/11 01:27 AM
11/24/11 01:27 AM
Posts: 1,600 Alberta Canada
StrokerAspen
Alberta Canada
X2 my first tall deck I bought in high school had round holes. My current tall deck has half moon holes.
-Kenny
[Re: StrokerAspen]
#1119790
11/24/11 10:39 AM
11/24/11 10:39 AM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
This stuff aint Rocket Science. It took me a while to realize a simple tape measure is the best way to check out a block. If you are looking at pictures then resort to things that are common to specific blocks. But, half moon holes vs full round is a bad way to code blocks.
Meaure the crank centerline to the deck surface. Very easy the only trick is finding crank centerline. That's half the crank diameter a small calculation on most any cell phone calculator and you are done.
9 9/16" is very close to a tall deck. Since that is 9.5625" and tall decks are advertised at 9.580" and some slip in just over 9.600". Most people will not notice that with a tape measure. Bore is also easy to measure. A flashlight can easily tell you if it is siamese bore or not. The head bolt arrangement is also easy. The cam tunnel requires knowing the cam tunnel bore for diffenent arrangements. Sometimes that requires a phone call if you do not have some known blocks around to measure from. The lifter angle is also fairly easy. 59 degree is easy to determine. 48 is the most common is the optional angle. Some 9.200" and shorter blocks were done 47. This is no biggy as all it changes is the cam ordering information.
HAPPY BLOCK HUNTING
Leon
[Re: tubtar]
#1119794
11/26/11 11:26 PM
11/26/11 11:26 PM
Leon441
Lynchburg, VA
The Ford main blocks are narrowed in the caps and web to accomodate the narrow bearing.
The 340 -360 deal is a little more difficult because most all of them use a rear cap for 360 pans. A few have thought they had a 360 block by looking at the rear cap and later found they were wrong.
Leon
