1973 Challenger Clutch switch "no crank" #1119689
11/23/11 11:37 AM
11/23/11 11:37 AM
Temple, Texas
scoutsr2 Offline OP
scoutsr2  Offline OP
Temple, Texas
Not much axperience with 4 speed cars...Just about done with the resto on this car but I can not get it to crank unless I ground the wire going to the starter relay from the clutch switch. Not sure that I understand how this switch works...looks like a coil spring. Is this part available from anywhere still? I would appreciate some guidance/baby sitting on this one.
Re: 1973 Challenger Clutch switch "no crank" [Re: scoutsr2] #1119690
11/23/11 01:22 PM
11/23/11 01:22 PM
I have one but not sure if it's a B or an E body one & I beleive there is a diff. let me grab it & post a pic & see if it has continuity. Dont think they are avail anymore
Re: 1973 Challenger Clutch switch "no crank" [Re: RapidRobert] #1119691
11/23/11 01:57 PM
11/23/11 01:57 PM
Slidell, LA
Plum440 Offline
Plum440  Offline
Slidell, LA
Pull the switch out and ground the terminal on the relay. Just don't start it in gear.
70 Challenger, 440, 4-speed, pLuM cRaZy
71 VW Super Beetle Convertible, Lemon Yellow
A couple of Jeeps…
Re: 1973 Challenger Clutch switch "no crank" [Re: Plum440] #1119692
11/23/11 03:47 PM
11/23/11 03:47 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Cars survived 70+ years without a clutch safety switch, just use your head and don't start it in gear.
Re: 1973 Challenger Clutch switch "no crank" [Re: scoutsr2] #1119693
11/23/11 04:24 PM
11/23/11 04:24 PM
Northern Va
Mopar73340 Offline
Mopar73340  Offline
Northern Va
I just rigged up a small toggle switch under the dash on my 73 that works just like the clutch switch. I have to "close" the switch before the starter will work. It Also will keep anyone else from being able to start the car.
Re: 1973 Challenger Clutch switch "no crank" [Re: scoutsr2] #1119694
11/23/11 06:22 PM
11/23/11 06:22 PM
Yes can bypass it but assumed you wanted to stay OE. Here's the one I have
Re: 1973 Challenger Clutch switch "no crank" [Re: RapidRobert] #1119695
11/23/11 06:28 PM
11/23/11 06:28 PM
KS
MoparKansas Offline
MoparKansas  Offline
KS
Jules the Wiperman sells and restores those switches. I had him do mine, but no pics. Great guy to deal with.
Re: 1973 Challenger Clutch switch "no crank" [Re: MoparKansas] #1119696
11/25/11 03:36 PM
11/25/11 03:36 PM
Temple, Texas
scoutsr2 Offline OP
scoutsr2  Offline OP
Temple, Texas
Thanks, we'll look at that. Do plan to keep it OE and really dont want to have where some goober might be moving the car for us and screw somone elses ride up.
Re: 1973 Challenger Clutch switch "no crank" [Re: scoutsr2] #1119697
11/25/11 04:22 PM
11/25/11 04:22 PM
MR_P_BODY Offline
MR_P_BODY  Offline
That switch is just the end of the ground circuit..
see if you can put a VOM on the wire and then ground
and move the pedal to see if the switch works
