harmonic balancer #1118019
11/20/11 09:12 PM
11/20/11 09:12 PM
okla.
sam64 Online content OP
sam64  Online Content OP
okla.
what is the preferred balancer for a 400 based 512,tci,fluid damper,etc?will be under 7,000 rpm,thank,sam.
Re: harmonic balancer [Re: sam64] #1118020
11/20/11 09:39 PM
11/20/11 09:39 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Well I guess I will be the minority here that likes a Fluidamper I have used them on all my engines and a few more that I built for friends.
Gus
64 Plymouth Savoy
Dana 60
Re: harmonic balancer [Re: sam64] #1118021
11/20/11 09:40 PM
11/20/11 09:40 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Most on here will tell you ATI.
However, we went with one of these http://www.professional-products.com/dampersProductchrysler.php on my motor as it also isn't turning over 7K and Scott has had really good results in the past with them.
The only thing to note is remove each screw around the orange ring and add a dab of Loctite to em.
Re: harmonic balancer [Re: WILD BILL] #1118022
11/20/11 10:34 PM
11/20/11 10:34 PM
SW Ohio
AAR-B4 Offline
AAR-B4  Offline
SW Ohio
I use the Professional Products balancer also.
It is SFI approved so it was tested at 12,000 rpm.
flame on....
Re: harmonic balancer [Re: AAR-B4] #1118023
11/20/11 11:00 PM
11/20/11 11:00 PM
Lehigh Acres, Florida
rickstershemi Offline
Rickster
Re: harmonic balancer [Re: sam64] #1118024
11/20/11 11:04 PM
11/20/11 11:04 PM
Boise
Moparteacher Offline
Boise
Re: harmonic balancer [Re: sam64] #1118025
11/20/11 11:05 PM
11/20/11 11:05 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
We all know that Fluidampr is the BEST!
Re: harmonic balancer [Re: Thumperdart] #1118026
11/21/11 12:42 AM
11/21/11 12:42 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I have had this one on my street eng for years with no problems. Ron
http://chucker54.stores.yahoo.net/prosport1.html
Re: harmonic balancer [Re: 383man] #1118027
11/21/11 09:32 AM
11/21/11 09:32 AM
WASHINGTON, PA
11secaarcuda Offline
WASHINGTON, PA
Any one else on this one? It looks like a good price?
67 Dart GT 340 4 speed
70 AAR Cuda 408 6 barrel
96 Indy Ram original owner
2011 Hemi Durango
Re: harmonic balancer [Re: 11secaarcuda] #1118028
11/21/11 02:33 PM
11/21/11 02:33 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I can also tell you it is made in Australia and not China.
Here it is on my eng. And all the belts line up fine. Ron
Re: harmonic balancer [Re: rickstershemi] #1118029
11/21/11 02:36 PM
11/21/11 02:36 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I thought the Professional Products dampers had a reputation for the outer ring spinning on the hub. Isn't that the brand that board member "RAMM" had fail during their EMC pulls a couple of years ago, or am I mistaken as to which damper they were using? Please correct me if I'm wrong.
Re: harmonic balancer [Re: 383man] #1118030
11/21/11 04:50 PM
11/21/11 04:50 PM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
I have one on my 408 and I needed the AR .125 crank spacer for some reason. Pulley needed to come out that far.
It's a nice damper though.
Re: harmonic balancer [Re: 383man] #1118031
11/21/11 05:06 PM
11/21/11 05:06 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
That looks a lot like this one from Summit ?!?!? What do you think?
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: harmonic balancer [Re: BradH] #1118032
11/21/11 05:09 PM
11/21/11 05:09 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Perhaps that's the reason Scott said to add the Loctite to each of the screws
Re: harmonic balancer [Re: Hemi Allstate] #1118033
11/21/11 05:20 PM
11/21/11 05:20 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Mark
Sure looks the same. And it is SFI approved. I have used two of them on my eng and my buddies. I liked the fact that my alt belt lined up perfect. I know the ATI balancer does not line up right with stock pulleys. And I heard that the one's made in Australia are usually good ones. Ron
Re: harmonic balancer [Re: WILD BILL] #1118034
11/21/11 07:19 PM
11/21/11 07:19 PM
Couldn't say for sure....mine is a solid non-sfi unit...?????
Rickster
Re: harmonic balancer [Re: rickstershemi] #1118035
11/21/11 07:44 PM
11/21/11 07:44 PM
Renton Washington
Triple Threat Offline
Renton Washington
ATI is the best ......
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: harmonic balancer [Re: Triple Threat] #1118036
11/21/11 08:08 PM
11/21/11 08:08 PM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
Agreed, but they are also the most expensive.
If I had a more serious effort race engine with 20-25k in it, I would. But instead I spent the difference on a distributor.
I just have a street engine and I felt the ATI might be overkill on it, so I got the same one as the guys above, but for a smallblock.
It's nicely made, looks nice and people seem happy with them.
Re: harmonic balancer [Re: sam64] #1118037
11/21/11 09:39 PM
11/21/11 09:39 PM
Long Island, NY
B1Ken Offline
B1Ken  Offline
Long Island, NY
It's been about 3 years since I've posted here but I just thought I'd check it out for old times sake. I USED to use Fluidampers and I also USED to break crankshafts regularly. Since I switched to ATI in 2002 I haven't broken a single crank. My engines are 511 B-1's which I run in Super Gas.
Ken Bowers
Re: harmonic balancer [Re: B1Ken] #1118038
11/21/11 09:42 PM
11/21/11 09:42 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Ken Bowers
I`ve heard this a few times and it boils down to quality controll plain and simple or mine and many others that use Fluidampr`s would be breaking cranks too.
