Re: harmonic balancer
[Re: sam64]
#1118020
11/20/11 09:39 PM
11/20/11 09:39 PM
Posts: 10,556 Rittman Ohio
fourgearsavoy
Rittman Ohio
Well I guess I will be the minority here that likes a Fluidamper I have used them on all my engines and a few more that I built for friends. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: sam64]
#1118021
11/20/11 09:40 PM
11/20/11 09:40 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
Most on here will tell you ATI.
However, we went with one of these http://www.professional-products.com/dampersProductchrysler.php on my motor as it also isn't turning over 7K and Scott has had really good results in the past with them.
The only thing to note is remove each screw around the orange ring and add a dab of Loctite to em.
[Re: WILD BILL]
#1118022
11/20/11 10:34 PM
11/20/11 10:34 PM
Posts: 685 SW Ohio
AAR-B4
SW Ohio
I use the Professional Products balancer also. It is SFI approved so it was tested at 12,000 rpm. flame on....
[Re: rickstershemi]
#1118029
11/21/11 02:36 PM
11/21/11 02:36 PM
BradH
I thought the Professional Products dampers had a reputation for the outer ring spinning on the hub. Isn't that the brand that board member "RAMM" had fail during their EMC pulls a couple of years ago, or am I mistaken as to which damper they were using? Please correct me if I'm wrong.
[Re: 383man]
#1118030
11/21/11 04:50 PM
11/21/11 04:50 PM
Posts: 1,074 detroit, mi
POS Dakota
detroit, mi
I have had this one on my street eng for years with no problems. Ron
http://chucker54.stores.yahoo.net/prosport1.html
Any one else on this one? It looks like a good price?
I can also tell you it is made in Australia and not China.
Here it is on my eng. And all the belts line up fine. Ron
I have one on my 408 and I needed the AR .125 crank spacer for some reason. Pulley needed to come out that far.
It's a nice damper though.
[Re: BradH]
#1118032
11/21/11 05:09 PM
11/21/11 05:09 PM
WILD BILL
BROOK PARK, OH
Perhaps that's the reason Scott said to add the Loctite to each of the screws
[Re: Hemi Allstate]
#1118033
11/21/11 05:20 PM
11/21/11 05:20 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
That looks a lot like this one from Summit ?!?!? What do you think? Mark
Sure looks the same. And it is SFI approved. I have used two of them on my eng and my buddies. I liked the fact that my alt belt lined up perfect. I know the ATI balancer does not line up right with stock pulleys. And I heard that the one's made in Australia are usually good ones. Ron
[Re: WILD BILL]
#1118034
11/21/11 07:19 PM
11/21/11 07:19 PM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
Couldn't say for sure....mine is a solid non-sfi unit...?????
Rickster
[Re: Triple Threat]
#1118036
11/21/11 08:08 PM
11/21/11 08:08 PM
POS Dakota
detroit, mi
ATI is the best ......
Agreed, but they are also the most expensive. If I had a more serious effort race engine with 20-25k in it, I would. But instead I spent the difference on a distributor.
I just have a street engine and I felt the ATI might be overkill on it, so I got the same one as the guys above, but for a smallblock. It's nicely made, looks nice and people seem happy with them.
