Re: Pics and schematic questions for '69 B-body bulkhead
[Re: Eagleone1983]
#1118008
11/20/11 09:02 PM
11/20/11 09:02 PM
RapidRobert
Yes it is difficult plus a mirror image 'cause sometimes you dont know which side you are on. I keep checking it several times and check nearby colors to help me. EDIT www.mymopar.com has wiring diagrams
[Re: Eagleone1983]
#1118010
11/21/11 12:31 AM
11/21/11 12:31 AM
RapidRobert
I dont have an ans for you on that particular one I just keep comparing back & forth from the schematic to whats in front of me on the car till something gels.
[Re: Eagleone1983]
#1118011
11/21/11 02:10 AM
11/21/11 02:10 AM
Posts: 21,547 N.E. OHIO, USA
A12
N.E. OHIO, USA
Could somebody please post pics of the factory correct engine side bulkhead connectors for a '69 Roadrunner 383 auto. I would just use the wiring diagram to figure it out but I don't understand how they reference it. Is the top bulkhead connector on the wiring diagram supposed to be the top connector on the bulkhead? I haven't been able to find any pics to confirm this but have found one that contradicts my thinking.
The way it shows on the wire diagram is the top connector is contains the wires for the headlights, turn signals, low brake warning light, and the yellow wire to the starter relay. The middle connector has the dark blue fusible link to the starter relay, gray wire to oil pressure sensor, etc... and the bottom connector has the windshield wiper motor and backup light switch wires. Am I reading that right?
Yes you're reading it correctly.....not that this has anything to do with the bulkhead but it may be of a little help. This is the plug that goes on the back of the headlight switch on the back side of the dash, see how the connections are at the same angle and you can match the colors. If you go to the top of the diagram you can see the two connections and see where 1 and 1 and 4 and 4 are and if you go to the bulkhead connections you will see the letters of the junction are on the plugs too.
