question on fuel injection #1117617
11/20/11 03:13 AM
11/20/11 03:13 AM
fredericksburg,va
cudaman1969 Online sleepy OP
cudaman1969  Online Sleepy OP
fredericksburg,va
since i can't get any response on my other post i'll break it down into smaller questions.do they make an electronic fuel injection control just to control the fuel and not the spark or is it tied together in some way? been reading some other posts and they all seem too do both.
Re: question on fuel injection [Re: cudaman1969] #1117618
11/20/11 03:35 AM
11/20/11 03:35 AM
Grande Prairie, Alberta, Can.
CW25 Offline
CW25  Offline
You can run a old school dist and just run hte fuel side of most EFI systems. Not sure why you would want to do this but it is doable. I personally like to change the timing with just a few clicks of then mouse but I suppose a timing light and wrench works as well.
11.67@118 1.88 60' with only 7-8 lbs of boost. Turbocharged, megasquirted, 407 BB, 440 source heads, roller cam, 9:1 comp. http://s292.photobucket.com/albums/mm14/beansgracie
Re: question on fuel injection [Re: cudaman1969] #1117619
11/20/11 09:08 AM
11/20/11 09:08 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Megasquirt will go either way.
Re: question on fuel injection [Re: cudaman1969] #1117620
11/20/11 01:07 PM
11/20/11 01:07 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
EZ-EFI only controls fuel, and as was said, any other EFI system can ignore ignition timing if you want. But if the system can control timing I would use it. It's interesting to see the affect that timing has on mid-range torque that most people never knew was there.
Re: question on fuel injection [Re: Mopar_Rich] #1117621
11/20/11 07:12 PM
11/20/11 07:12 PM
fredericksburg,va
fredericksburg,va
next question,i would like using my MSD 7 with one coil,this has a lot of fire power and multiple sparks per cycle, can these systems keep up with it?
Re: question on fuel injection [Re: cudaman1969] #1117622
11/20/11 07:47 PM
11/20/11 07:47 PM
Southington Ct.
turbobitt Offline
turbobitt  Offline
Southington Ct.
I know the FAST XFI has inputs for just about any type of trigger, Crank or distributer. The XFI would then trigger the MSD though a "points" wire output. Now you have your MSD ignition but timing control through XFI.
Allan G.
1970 Challenger w/572 Hemi street car and my pride and joy. 1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno. 1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
Re: question on fuel injection [Re: cudaman1969] #1117623
11/20/11 09:28 PM
11/20/11 09:28 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Absolutely. The XFI just drives the white wire as was said. I have set up quite a few MSD 7 systems with the XFI. The only consideration is to make sure the MSD is well separated from the XFI because of the electrical noise the MSD creates.
You would not use the spark retard or any of the other features in the MSD. The XFI handles all those, including rev limiters, but you can use the MSD rev limiters if you want.
Re: question on fuel injection [Re: Mopar_Rich] #1117624
11/21/11 01:24 PM
11/21/11 01:24 PM
IL
furious70 Offline
furious70  Offline
IL
x2 on going all the way and having the ecu do the timing too, it's so simple to do and gives so much control. I'd love to have the spark only side for carb'd vehicles!
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: question on fuel injection [Re: furious70] #1117625
11/21/11 02:06 PM
11/21/11 02:06 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I'm hooking a MSD 7531 to a XFI now. I could use a few tips. I have the FAST close to done and was getting stuff layd out for the MSD. I really want to add a racepak as well.
Rich it's David in KY. Still not running but getting close lol
Re: question on fuel injection [Re: FastmOp] #1117626
11/21/11 10:13 PM
11/21/11 10:13 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I run an old Electromotive TEC II with distributorless ignition. You can see it on the firewall in this pic.
It was a pretty advanced system for it's day. The biggest problem I had was the lack of support for it. Very few people know how to tune it. Unlike the EZ-EFI systems, these are compatible with up to 3 bar MAP sensors (30 psi manifold boost).
The TEC 3r is a more modern replacement. I haven't looked at the software for it so I can't comment on how it works.
www.getfuelinjected.com
- Stu Harmon
