Question for Mopar_Rich #1117261
11/19/11 11:11 PM
11/19/11 11:11 PM
Marilla, New York
RalleyA12 Offline OP
Marilla, New York
Hey Rich, I have a question for you. If I had a FAST EZ EFI on my car and wanted to up grade to a FAST XFI could I somehow use or transfer the fuel map from the EZ over to the XFI and save some of the hassle in tuning the XFI. Is there much difference in how they are wired ?
Re: Question for Mopar_Rich [Re: RalleyA12] #1117262
11/19/11 11:39 PM
11/19/11 11:39 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I will bet the answer to that is a big "NO"...but if there is a way to hook a computer to the EZ efi, that would be interesting to see...Besides, with XFI, you have to set up the timing and some other inputs to fire the engine, but once fired, it has the same learning ability for hitting the target AFR...
Re: Question for Mopar_Rich [Re: Dragula] #1117263
11/20/11 01:03 PM
11/20/11 01:03 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Dragula is correct on all points. No there's no way to move an EZ VE table to the XFI. But if you car is running well with the EZ, and the learning has had a chance, then your target AF numbers are good. So you can use the same targets with the XFI.
The self learning algorithms for cruise and WOT that the XFI uses is the same as the EZ so it would still work. I'm thinking of writing up a step-by-step procedure for setting up the XFI "Cranking and After Start" fuel tables. It's not that hard.
Re: Question for Mopar_Rich [Re: Mopar_Rich] #1117264
11/20/11 02:50 PM
11/20/11 02:50 PM
Marilla, New York
Marilla, New York
Thanks Rich, I didn't realize the XFI had the learning capability.
Re: Question for Mopar_Rich [Re: RalleyA12] #1117265
11/20/11 09:22 PM
11/20/11 09:22 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Version 2.0 is self learning, and only 2.0 is available now.
With self learning, my typical 3 to 4 hour tuning session on our engine dyno dropped to 30 minutes.
