What radiator should my 69 charger r/t 4 speed have? #1117170
11/19/11 08:35 PM
11/19/11 08:35 PM
Oakley CA
69charger440_6pa Offline OP
Oakley CA
My original radiator is long gone as is the fender tag to my car. I was wondering if anyone could help me figure out what radiator my car should have.
It's a 69 charger r/t 4 speed car.
440, original 18 spline 4 speed
Dana 60. Orig gear ratio not known.
It has the large radiator opening.
Thanks guys.
1969 Charger R/T under construction
2014 Ram 3500 Cummins
2006 Corvette Z06
2015 Corvette Z06
2014 BMW M5
Re: What radiator should my 69 charger r/t 4 speed have? [Re: 69charger440_6pa] #1117171
11/19/11 08:37 PM
11/19/11 08:37 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
It will either be an 055 , if 3.54 geared or an 054 if 4.10. Did the car have power disc brakes ?
Re: What radiator should my 69 charger r/t 4 speed have? [Re: JohnRR] #1117172
11/20/11 01:11 AM
11/20/11 01:11 AM
Oakley CA
Oakley CA
What's odd is the car had the bendix power booster
and disk brake master w/ drum brakes up front... Don't know how or why.
2006 Corvette Z06
2015 Corvette Z06
2014 BMW M5
Re: What radiator should my 69 charger r/t 4 speed have? [Re: 69charger440_6pa] #1117173
11/20/11 01:25 AM
11/20/11 01:25 AM
N.E. OHIO, USA
A12 Online content
A12  Online Content
N.E. OHIO, USA
Do the master cylinder lines exit on the driver's or passenger's side of the master cylinder?
From what I've seen if it has discs front then the lines exit on the passengers side...drums on the driver's is that what you are saying when you say it has a disc master cylinder?
Re: What radiator should my 69 charger r/t 4 speed have? [Re: A12] #1117174
11/20/11 01:27 AM
11/20/11 01:27 AM
N.E. OHIO, USA
A12 Online content
A12  Online Content
N.E. OHIO, USA
Oh and you could count the number of times the drive shaft rotates versus the wheel and check the ratio......4.1 vs 3.5..
Re: What radiator should my 69 charger r/t 4 speed have? [Re: A12] #1117175
11/20/11 09:47 AM
11/20/11 09:47 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
What size brakes were on the rearend ? Assuming it was the original rear axle 11" drums would have been a drum brake car and it would have been 3.54 geared , 10" drums would have been a disc brake car , but it could have been either. Again assuming the original rear there is a number on the pass ide tube that telss how the rear was originally assembled.
That said you have a 493 stroker , get the 054 , the only one that will complain about it will be your wallet $$$$
