enough fuel for nos? #1116405
11/18/11 09:56 PM
11/18/11 09:56 PM
Saskatchewan (SK)
79410aspenrt Offline OP
Saskatchewan (SK)
i have asked numerous people this question with answers all over the place.
i have a mallory comp 250 fuel pump. i want to run a 150 hp shot of nos.
will my 250 pump be able to handle this?
550 hp small block.
Re: enough fuel for nos? [Re: 79410aspenrt] #1116406
11/18/11 10:00 PM
11/18/11 10:00 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
yes easy.
Re: enough fuel for nos? [Re: 79410aspenrt] #1116407
11/18/11 11:33 PM
11/18/11 11:33 PM
550 hp small block.
It depends of course,what size pickup and line size to the front and what type and size fuel filters and where are they? Maybe, but not safely Magnafuel says there 275 pump is good to 750 HP, IF everything else(lines and fuel filters) are correct and the stars are aligned properly Why not have more fuel volume than you need You know if you like a 150 shot of NOS your going to go bigger
Re: enough fuel for nos? [Re: Cab_Burge] #1116408
11/18/11 11:36 PM
11/18/11 11:36 PM
Ma
Voluster Offline
Voluster  Offline
Ma
Plenty
I use a areomotive a 2000 and that does both my motor and my juice
for what your trying to do that will work fine
just make sure you have a separate regulator for the motor and the nitrous
Re: enough fuel for nos? [Re: 79410aspenrt] #1116409
11/19/11 09:58 AM
11/19/11 09:58 AM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
there guys out there with holley black pumps sprayin that amount with no prob's...i think mallory is a little better then the blk pump no?
Re: enough fuel for nos? [Re: 79410aspenrt] #1116410
11/19/11 12:14 PM
11/19/11 12:14 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I ran a 150 shot on the street with a stock mechancal pump, for like 5 years.
Re: enough fuel for nos? [Re: Challenger 1] #1116411
11/20/11 12:13 AM
11/20/11 12:13 AM
Oak Harbor, WA
W
Wicked49670dart Offline
W
Oak Harbor, WA
I use that pump with a 200 shot with no problems...Matt
70 Dart 3400 496 New Best 6.15@110.37 660ft, 9.76@135 with a 1.34 60ft
Re: enough fuel for nos? [Re: Wicked49670dart] #1116412
11/20/11 12:21 AM
11/20/11 12:21 AM
Saskatchewan (SK)
Saskatchewan (SK)
thanks guys for the comments.
i run -8 line from tank to filter then to pump. from pump to regulator, -8 also. then -6 from regulator which feeds both carbs.
how much et will i pick up from a 150 shot? best et now is a 11.54 @ 118.56 mph.
Re: enough fuel for nos? [Re: 79410aspenrt] #1116413
11/20/11 06:25 AM
11/20/11 06:25 AM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
You can run a 500hp shot with that pump, I have a lot of time slips that say you have way more than enough fuel.
Re: enough fuel for nos? [Re: 79410aspenrt] #1116414
11/20/11 10:32 PM
11/20/11 10:32 PM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
you'll probably cut a second off your times...
Re: enough fuel for nos? [Re: Biginchmopar] #1116415
11/21/11 12:58 AM
11/21/11 12:58 AM
Is that feeding both the motor and 500 HP NOS systems? If not what size do you recommend for both
Re: enough fuel for nos? [Re: Cab_Burge] #1116416
11/21/11 03:17 AM
11/21/11 03:17 AM
Carson City, Nevada
Carson City, Nevada
Cab,
With all the testing I have done with nitrous, I never found the need to go any bigger, ever!
That pump will feed a 750-800hp motor and a 500hp nitrous hit. Those pumps move a ton of fuel.
I always use a return style regulator.
