Quarter Stick Mods for Clean Neutral
#1116354
11/18/11 08:08 PM
11/18/11 08:08 PM
Posts: 89 oregon
ramcharger1964
oregon
Does anyone know if it is possible to home modify a Quarter Stick reverse pattern shifter so that I can add a clean neutral to my CRT 727????
Hell B!tch Racing Co.
Re: Quarter Stick Mods for Clean Neutral
[Re: ramcharger1964]
#1116356
11/18/11 10:29 PM
11/18/11 10:29 PM
Posts: 20,679 in a cattle trailer down by th...
Guitar Jones
I modified mine to use a solenoid shifter. Basically the same thing but neutral is now first, first is second and third is neutral. You can grind away the gate in the shifter and then add a small gate plate to get the gears you want if you aren't using an an air shifter.
[Re: rebel]
#1116357
11/18/11 10:35 PM
11/18/11 10:35 PM
my TA Cheeter shifter only reqd a decal change,
For what transmission?. I can't see how that would work. If its a reverse manual for a torqueflite, theres no more room for a clean nuetral position on the shifter itself. ![](/ubbthreads/images/graemlins/shruggy.gif)
#1116358
11/18/11 10:45 PM
11/18/11 10:45 PM
Guitar Jones
The way it works is reverse is neutral and reverse. You have to push the trans brake button for reverse. Neutral is now 1st gear, 2nd is 3rd and 3rd is now the clean neutral.
[Re: Guitar Jones]
#1116360
11/18/11 11:50 PM
11/18/11 11:50 PM
wow, I like that. does TA make a decal for the conversion?That could get confusing if you mess up with the new pattern. .
[Re: Plumb Wired]
#1116362
11/19/11 12:50 AM
11/19/11 12:50 AM
Yes, decal is available from Turbo Action, #70090
http://www.turboaction.com/frame.html
I have a Tranzact clean neutral VB in my Dart.
Mike Gray
Is that shifter modified at all?. looks like 1st gear detent is missing or i'm missing something. looks different from standard shifter for reverse manual valvebody.
#1116363
11/19/11 01:02 AM
11/19/11 01:02 AM
TA says you need to change the gate in order for the clean nuetral to work.
#1116364
11/19/11 06:57 AM
11/19/11 06:57 AM
Posts: 4,648 aotearoa
rebel
aotearoa
well i only changed the decal & the new configeration didn't take much to get the handle on it.
