Cam for Stroker 408
#1116219
11/18/11 01:52 PM
11/18/11 01:52 PM
Posts: 1,123 Seaford Delaware
JSR1485
Seaford Delaware
I am building a 408 for my Duster and it will be street driven and it will be a 4 speed with 3.23 gears with a 27" tall tire.
This is one cam I had laying around and was thinking about using in the 408 since I hear these engine like duration on the camshaft, let me what you guys think. It is a solid lifter Intake 540 lift Exhust 560 Duration Intake 248 and Exhaust 258 @ .050 Adv Duration Intake 284 and Exhaust 294
Switched to the dark side...
Re: Cam for Stroker 408
[Re: radar]
#1116222
11/18/11 06:20 PM
11/18/11 06:20 PM
JSR1485
Seaford Delaware
The heads I have are mild ported set of Factory steel heads with 2.02 valves. When my car was used for strip use only , I used this cam and heads on .030 over 360 with 11.5 pistons KB 190's and with a 4.10 gear the car went 11.80's On the 408 build I was hoping 9.5 compression with KB356 pistons
The Cam is a Crane Part # 690911
[Re: JSR1485]
#1116223
11/18/11 08:20 PM
11/18/11 08:20 PM
Posts: 3,719 Space Station #5
471Magnum
Space Station #5
The 275HL requires double springs, so unless you're heads are prepped for them, you need to step down to something a bit smaller.
I run the 274L in my 410 with lightly prepped J-heads. Pretty much the same spec as the 275 with a tad less lift. Still requires double springs though.
Anyway, it's probably the biggest cam I'd consider on the street. I have yet to really flog the motor and wind it out, but it's got plenty of grunt with a stock top end (t-quad on a dual plane). I knowingly compromised some performance to keep with stock appearance though.
-Jim
I can fix it... my old man is a television repairman. He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
[Re: 471Magnum]
#1116224
11/19/11 02:06 AM
11/19/11 02:06 AM
Posts: 27,471 So Cal
autoxcuda
So Cal
I run the 274S solid cam with my 416. It's got ported E-brock heads, 1 3/4 TTI stepped headers, M1 Single plane, 750 Silver Claw carb. Mine seems fairly decent on the street. I run errands in it after work. It took lots of tuning though.
It didn't like Champion plugs. Autolites last longer and run smoother. Also using Castrol 10-30 instead of Rotella 15-40 quieted the solid lifter noise quite a bit.
I just got my MSD E-curve to work on it. It made a noticable difference from a new MP electronic. Smoothed things out all around.
It's tough to get to 6,000 in 1st or 2nd on the street. Just no traction with my tires. I can hit 6,000 on the track. It doesn't seem to "pull hard" from 5K to 6K, but that's 110 to 130 mph and I'm fighting the air.
[Re: radar]
#1116226
11/19/11 08:39 PM
11/19/11 08:39 PM
JSR1485
Seaford Delaware
I ran this cam with these heads for years , unit my chip fell out out of MSD box in the water box and I spun the motor to 8000 rpm and wiped a couple mains outs. So I was thinking to save some $$$ to re-use the heads and cam/lifters and redo the bottom to 408 ci. I was just not sure how streetable this cam would be with more cube's?
