There are two different versions of the 415 HP M.W., 1963 had a .065 dome and the 1964 had a .110 or .120 dome hieght. The 425 HP pistons are the same for both years
![](/ubbthreads/images/graemlins/scope.gif)
Iron heads and pump gas can be catostrophic IF, or WHEN, pinging or detonation occurs
![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
If you absolutely must use those pistons, either year, then I would use the 452 head and a 440 Fel Pro Perma Torque stock type head gasket to control the compression ratio. The 452 castings had hard exhuast seats from the factory and big combustion chamber for detonation control
