HP for 200mph #1115651
11/17/11 06:06 PM
11/17/11 06:06 PM
Greenville, WI
Big B Offline OP
Big B  Offline OP
Greenville, WI
How much power would it take to put a 3500lb car over 200mph?
Re: HP for 200mph [Re: Big B] #1115652
11/17/11 06:13 PM
11/17/11 06:13 PM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
What body style???
Even a slippery car and a good chassis, it's going to be well north of 2000.
Re: HP for 200mph [Re: Big B] #1115653
11/17/11 08:06 PM
11/17/11 08:06 PM
Tuscaloosa, Alabama
speedfreak440 Offline
Tuscaloosa, Alabama
Over what distance? 1/4, full mile, absolute??
As stated before, bodystyle means alot here too.
Re: HP for 200mph [Re: Big B] #1115654
11/17/11 08:30 PM
11/17/11 08:30 PM
organ
maximum entropy Offline
organ
top speed has less to do with weight and power than it has to do with coefficient of drag. a drop tank at bonneville could prolly hit 200 with maybe 300 rwhp? as an added complication, traction usually becomes the limiting factor when you have a lot of power in a brick. you're up against an aerodynamic "brick wall". spinning your wheels trying to push the car through the air. the salt doesn't have real good traction, relatively speaking, so minimizing aerodynamic drag is job one. then move on to the other stuff. weight is often times your friend when going for all out speed. weight can improve traction. i would love to take my scamp to the salt and see if it will do 200, but i know that as it sits, though it may have enough power, it's a box on a box, and there is no way that's gonna happen. it would have to be MUCH slipperier.
Re: HP for 200mph [Re: maximum entropy] #1115655
11/17/11 08:41 PM
11/17/11 08:41 PM
Greenville, WI
Big B Offline OP
Big B  Offline OP
Greenville, WI
Sorry. 200mph in a 69 roadrunner. I was guessing 2000+ hp.
Re: HP for 200mph [Re: maximum entropy] #1115656
11/17/11 08:42 PM
11/17/11 08:42 PM
Greenville, WI
Big B Offline OP
Big B  Offline OP
Greenville, WI
Sorry. 200mph in the 1/4 with a 69 roadrunner. I was guessing 2000+ hp.
Re: HP for 200mph [Re: Big B] #1115657
11/17/11 09:07 PM
11/17/11 09:07 PM
Trumbull,CT.
Trumbull,CT.
Lotsa ways to make that kinda power these days.
Re: HP for 200mph [Re: jim sciortino] #1115658
11/17/11 09:45 PM
11/17/11 09:45 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Paging Hemifred, Hemifred to the thread, please...
Re: HP for 200mph [Re: jim sciortino] #1115659
11/17/11 09:47 PM
11/17/11 09:47 PM
Greenville, WI
Big B Offline OP
Big B  Offline OP
Greenville, WI
My car currently has 730hp and runs 10's. Car feels really slow to me now.
Thinking about really stepping it up to bring back the fun. Thinking big turbo motor.
Re: HP for 200mph [Re: Big B] #1115660
11/17/11 09:55 PM
11/17/11 09:55 PM
organ
organ
are you talking about 200 in the 1/4? piece of cake!
Re: HP for 200mph [Re: Big B] #1115661
11/17/11 09:58 PM
11/17/11 09:58 PM
Trumbull,CT.
Trumbull,CT.
730hp @ 3500# should be well into the 9s. I'd square away the car with the current engine before I'd make a big jump.
Although, twins on a bigblock will certainly get rid of the "feels really slow" issue.
Re: HP for 200mph [Re: Big B] #1115662
11/17/11 10:02 PM
11/17/11 10:02 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
you should be well into the 9's w/ that kind of power. To hit 200 you might need to do a few things. Lighten the car up. Block off the grill, use a front spoiler lower the car.... I used an online calculator and a 3650 lb car would need about 1400 hp to hit 200 in the 1/4. Not saying that's too much or not enough, just what the computer spit out. As mentioned a wedged shaped car is going to do it easier than a brick.
Coming soon!!!!
Re: HP for 200mph [Re: Mr.Yuck] #1115663
11/17/11 10:51 PM
11/17/11 10:51 PM
Greenville, WI
Big B Offline OP
Big B  Offline OP
Greenville, WI
With me in the car it weighs 3750lbs. The car is tuned about as fast as it will go. Might hit a 9 if it's cold enough I guess.
Re: HP for 200mph [Re: Mr.Yuck] #1115664
11/17/11 10:53 PM
11/17/11 10:53 PM
NASHVILLE
MAVERICKSHEMI Offline
NASHVILLE
http://vexer.com/automotive-tools/speed-rpm-calculator Try this and see if it answers some questions
Re: HP for 200mph [Re: Mr.Yuck] #1115665
11/17/11 11:34 PM
11/17/11 11:34 PM
Oklahoma
hemiiroc Offline
hemiiroc  Offline
Oklahoma
1400 in a 3650lb car won't get anywhere close to 200
Re: HP for 200mph [Re: hemiiroc] #1115666
11/17/11 11:54 PM
11/17/11 11:54 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
No Problem call these guys for engine details..
http://www.prolineracing.net/
What about the chassis??
Set another $50K+ aside for that too.
You are at dang near Pro Mod levels with that setup.
Just look at Jimmy's Dart, not sure what it ended up running, but your over 1000 lbs more too
Id say $150K could get you out for half a season...maybe...
Re: HP for 200mph [Re: hemiiroc] #1115667
11/18/11 12:58 AM
11/18/11 12:58 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
My calculator says about double will do the deed.
Kevin
Re: HP for 200mph [Re: Bob_Coomer] #1115668
11/18/11 04:25 AM
11/18/11 04:25 AM
Renton Wa
topfueldart Offline
topfueldart  Offline
Renton Wa
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
Re: HP for 200mph [Re: Big B] #1115669
11/18/11 06:21 AM
11/18/11 06:21 AM
Hamburg / Germany
Den300 Offline
Den300  Offline
Hamburg / Germany
http://so1968.so.ohost.de/cars3.html
the guy with the silver coronet (Matt) goes 191mph on a german highway.
Might send him a mail. Car could go faster. it is a 440 with some good internal parts.
Dennis
Hamburg/Germany
69 Chrysler 300
446cui Dual Quad
12.64 @ 110.7
Re: HP for 200mph [Re: Den300] #1115670
11/18/11 08:10 AM
11/18/11 08:10 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Dennis
Why yea, some template ported 906's, and atleast a 509 purple shaft.... LOL
