First Thanks Moparts and All you folks that have helped out with info
Now I need some on my brake pedal assembly Is there some sort of connector that goes between the pedal hole and the booster arm as mine has about three or so inches difference in the height alinment it ahs been torn down for years and the folks didnt mark everything so I am trying to redo it kinda blind. I did buy a new cylinder booster setup and it was a match to the old one but I dont know if there is a peice or even if I have it.
Thanks again
God Bless
