408 W2 cam question
#1115060
11/16/11 02:29 PM
11/16/11 02:29 PM
Posts: 804 Houston, Texas
racerx20
Standard but OK
Standard but OK
Houston, Texas
About to have a 408 W2 motor built and I'm looking for some opinions. Looking at a mill in the 530hp range for my 69 Dart. The cam that has been suggested is approx .600 lift 252/256 flat tappet, solid. Will be running 3500-4000 stall w/3:55. My main concern is streetability since that is what the car does 99% of the time(weekend/nice weather cruiser). Anyone have experience with a stroker small block and a cam in this range? How was it on the street? Thanks
1972 Road Runner
1988 Shelby CSX-T
Re: 408 W2 cam question
[Re: Danan]
#1115066
11/17/11 01:13 AM
11/17/11 01:13 AM
Posts: 815 PNW
Danan
PNW
To continue my post above:
If all you want is a street engine, why do you want to run W2 heads? They are way too expensive (heads, offset rockers, special rocker shafts, etc) if you aren't going to utilize the flow that they offer.
My suggestion for a street engine would be 408" shortblock with 10:1 actual compression, out of the box edelbrock heads, a Comp Cams .525" solid cam, and a six pack induction. You could sell your W2s and valve gear and recoup money to buy the Edelbrocks/valve gear.
To save money, you could always throw a 750 vacuum secondary Holley on there with a modern single plane manifold.
I'd still suggest 3.91 gears, and your converter sounds good so long as it's a high quality (read: efficient) unit. Having the local hack shop "bend the fins" to increase the stall at the expense of efficiency is NOT the answer.
Naturally, you'll want to run quality headers and 2.5" exhaust.
You would be far more happy with the above combo (or one similar to it) than you would be with what you described above, in my opinion..
[Re: Danan]
#1115068
11/17/11 01:29 AM
11/17/11 01:29 AM
Posts: 795 Glendale Az
Darryls-Demon
Glendale Az
I sure wish Chevy and Ford guys had ideas like this, It would be much easier to kick butts.
