Re: Cope Racing Bolt in Sprag
[Re: eaglesguy1981j]
#1115011
11/16/11 10:26 PM
11/16/11 10:26 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
If you are going to spend money on a bolt in sprag get this 1 it is a nicer unit it comes with shouldered bolts instead of those goofy little things with the brass ferels.And the 16 elements instead of 12 is a large increase in holding and they will not roll over like the 12 rollers will. http://www.coanracing.com/Catalog.asp?ProductDetail=25
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
#1115012
11/16/11 11:29 PM
11/16/11 11:29 PM
Posts: 75,125 A Banana Republic near you.
JohnRR
http://www.aandatrans.com/Products/727-6-Bolt-Ultimate-Sprag-(1966-1989)__K22961US-6.aspx
Ive seen that one as well. Cope sells it too. But I figured the 4 bolt version would be just fine for me. Not a race car. Just warmed 440
This one is nothing more than a replacement for the stock sprag should it come loose in the case , a complete waste of money if your outer race is still secure in the case .
buy either the A+A linked above or the Coan , both have 16 rollers and will make it very hard to have a sprag failure , the rollers will not roll over but you could still blow the back of the trans case out if you do something real stupid.
[Re: JohnRR]
#1115013
11/17/11 03:55 AM
11/17/11 03:55 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
![](/ubbthreads/images/graemlins/iagree.gif)
If your going to replace it, get the super sprag. I used the A&A one (Bought from Cope), but the Coan one looks nice too. I have extra 1/4" fine thread allen head bolts for the sprag if you need some. My supersprag was missing a bolt, so I ordered up a box of 100, only have 99 remaining so act fast. lol ![](/ubbthreads/images/graemlins/hammer.gif)
