Re: New project ( stock suspension 275 drag radial 72 duste
[Re: 440charger500]
#1114732
02/04/13 09:10 PM
02/04/13 09:10 PM
Posts: 105 michigan
jbmopars
michigan
Finally another missing piece to the puzzle has been found. Haven't had much progress lately other than saving some money. Now I can start all over again with that. My son and I just got this put out back in the shop. It is an Arrington R3 short deck W8 358 c.i. ex Craftsman Truck motor that originally came from Brad Keslowski. It has been converted to a wet sump by the previous owner, has Bryant billet crank, Carrillo rods, Diamond pistons, .760" solid roller, new Jesel roller lifters, Jesel titanium rocker set up, titanium valves, and has just been freshened. I will have to take some compression out of it, put a turbo grind cam in it, and probably change the exhaust valves from ti to inconel. It was all the right pieces I was looking for, and for the right price. ![](http://i405.photobucket.com/albums/pp131/jbpaintphotos/1972%20DUSTER/037_zpsc4949289.jpg)
[Re: 412 SB Duster]
#1114745
04/27/13 09:34 AM
04/27/13 09:34 AM
Posts: 105 michigan
jbmopars
michigan
Looking good! Any chance you'll make it out this year?
Al
Thanks Al, I wish I could have it done that quick, but I'm trying to build the car without having any debt, and that just means more time. I know that I'm getting closer but still have alot to spend.
[Re: jbmopars]
#1114746
04/27/13 01:06 PM
04/27/13 01:06 PM
Posts: 11,734 Portage,michigan
B3422W5
Portage,michigan
Lookin great, Jody...still kickin myself in the butt for not buying that car when i had the chance.. ![](/ubbthreads/images/graemlins/hammer.gif) glad you got it, you do awesome work..cant wait to see it run when you get her done ![](/ubbthreads/images/graemlins/thumbs.gif)
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam, footbrake street/strip car Best so far, 10.32 1/4 1.41 best 60 foot 6.56 at 104.17
[Re: Darryls-Demon]
#1114749
04/28/13 09:33 PM
04/28/13 09:33 PM
Posts: 6,151 Melbourne , Australia
LA360
It would probably be a custom core, although a lot of the Comp Eliminator stuff would be running 60mm camshafts with 112 + lobe separation angles. I would imagine this engine has a 50mm core anyway
Alan Jones
[Re: Darryls-Demon]
#1114751
04/29/13 07:38 AM
04/29/13 07:38 AM
LA360
The only blocks that I recall having the the 60mm tunnel were the 2.25" main blocks. As far as I know the Craftsman truck stuff had the 50mm roller tunnel. My R3 that I had was 318 main with a 50mm unnel and a 9" deck. Sorry for the hijack ![](/ubbthreads/images/graemlins/grin.gif)
Alan Jones
