shift lights #1113870
11/14/11 10:05 PM
11/14/11 10:05 PM
MD-USA
Dodgeguy101 Offline OP
MD-USA
School me on stand alone shift lights. I was to cheap when I bought the tach to get one, but now I think I do. What is a decent one to get and what is involved with all the parts needed to make it work. I have an MSD box if that matters. Thanks Bill
Re: shift lights [Re: Dodgeguy101] #1113871
11/15/11 04:08 AM
11/15/11 04:08 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
MSD would be my choice.. The info you need is in the cat IIRC..
I am truckless..
Re: shift lights [Re: 340SHORTY] #1113872
11/15/11 08:20 AM
11/15/11 08:20 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I have an MSD one myself. It just plugs into the tach port on the MSD box. You change the chip in it to change shift points.
Just a note: If you use a light and a tach, the shift light will flash a couple hundred RPM below what your chip says. That is so you have time to get the shift in before you go above your target RPM.
Re: shift lights [Re: slantzilla] #1113873
11/15/11 09:18 AM
11/15/11 09:18 AM
MD-USA
MD-USA
Many thanks to both of you for the advice.
Re: shift lights [Re: Dodgeguy101] #1113874
11/15/11 09:28 AM
11/15/11 09:28 AM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
I got one here:
http://raptorperformance.com/
Easy to install. One wire to ground, another to a switched power source, and the last one to negative side of the coil.
Re: shift lights [Re: 68KillerBee] #1113875
11/15/11 12:06 PM
11/15/11 12:06 PM
Eden, Texas
Strawdawg Offline
Strawdawg  Offline
Eden, Texas
I also have one from Raptor...works very well
Steve
