Parking brake mechanism 70 Cuda something missing here? #1113793
11/14/11 06:26 PM
11/14/11 06:26 PM
Houston Texas
PAINT IT BLACK Offline OP
Got a CHIP on my shoulder
Houston Texas
This is a random pic off the net, but mine looks similar. Is there supposed to be some sort of retainer or rivet or something at this slotted opening? I know the release lever is supposed to move, but is there supposed to be some kind of bolt or something in there to limit the motion? Otherwise, what is the purpose of the slot? Referring to inside the red circle in the pic.
Re: Parking brake mechanism 70 Cuda something missing here? [Re: PAINT IT BLACK] #1113794
11/15/11 12:33 AM
11/15/11 12:33 AM
Houston Texas
Houston Texas
Someone knows this one... a little help?
Re: Parking brake mechanism 70 Cuda something missing here? [Re: PAINT IT BLACK] #1113795
11/15/11 12:47 AM
11/15/11 12:47 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
A tab from the release lever to limit travel...
Re: Parking brake mechanism 70 Cuda something missing here? [Re: PAINT IT BLACK] #1113796
11/15/11 12:50 AM
11/15/11 12:50 AM
Montreal,Quebec,Canada
JulesdaWiperman Offline
super gas
super gas
There should be a stop lever tang. Not crucial but that is what stops the lever from going to far.
Jules
Re: Parking brake mechanism 70 Cuda something missing here? [Re: JulesdaWiperman] #1113797
11/15/11 01:42 AM
11/15/11 01:42 AM
Houston Texas
Houston Texas
Mine appears to be missing. Is it just a bent over tab of metal from the release or is it something that can be replaced. Whatever it is, mine aint there....
I seem to have too much motion in my release lever. It would be nice if it were tighter. Its real sloppy.
Re: Parking brake mechanism 70 Cuda something missing here? [Re: PAINT IT BLACK] #1113798
11/16/11 10:13 AM
11/16/11 10:13 AM
super gas
super gas
Just a bent over tab that stops the lever from going to far.
Jules
Re: Parking brake mechanism 70 Cuda something missing here? [Re: PAINT IT BLACK] #1113799
11/16/11 12:40 PM
11/16/11 12:40 PM
Houston Texas
Houston Texas
Yep. Not there. I stuck a small bolt in there from behind and threaded a nut on the front side. It improved the functionality quite a bit... of course it doesn't look right. I don't care enough to buy an entire assembly to replace it though.
Re: Parking brake mechanism 70 Cuda something missing here? [Re: PAINT IT BLACK] #1113800
11/16/11 01:24 PM
11/16/11 01:24 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
When it's mounted in the car no ones gonna see it...
Re: Parking brake mechanism 70 Cuda something missing here? [Re: 1_WILD_RT] #1113801
11/16/11 03:34 PM
11/16/11 03:34 PM
Houston Texas
Houston Texas
indeed. I used a stainless acorn nut on the exposed side anyhow, so it really doesn't look bad anyway. I'm just about getting this sucker back on the street at this point! Doing nobody any good locked up in my shop like it has been for the last couple years... A few more weeks and we'll be back in the action!
Re: Parking brake mechanism 70 Cuda something missing here? [Re: PAINT IT BLACK] #1113802
11/16/11 03:37 PM
11/16/11 03:37 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
You can see by the picture I took, mine isn't pretty but it goes down the road just fine...
Re: Parking brake mechanism 70 Cuda something missing here? [Re: 1_WILD_RT] #1113803
11/16/11 04:28 PM
11/16/11 04:28 PM
Houston Texas
Houston Texas
Looks fine to me.
Re: Parking brake mechanism 70 Cuda something missing here? [Re: PAINT IT BLACK] #1113804
11/16/11 05:31 PM
11/16/11 05:31 PM
Houston Texas
Houston Texas
For those who have stumbled on this thread several years in the future who happen to have the same weird problem with the missing "tang"...
This bolt solution I have come up with is only a temporary fix. The bolt head catches on the ratchet arm from time to time since it is a pretty tight fit. The real way to fix this is to either replace the part or fix it by welding/grinding a piece of donor metal.
Once I have the car back on the road and have worked through the more serious bugs, I will remove the assembly and repair it correctly.
Re: Parking brake mechanism 70 Cuda something missing here? [Re: PAINT IT BLACK] #1113805
11/16/11 10:25 PM
11/16/11 10:25 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Looks fine to me.
Well mine is all black & dirty, the pictures you & Jules posted are bare metal & gloss black which is correct...
Re: Parking brake mechanism 70 Cuda something missing here? [Re: 1_WILD_RT] #1113806
11/17/11 12:01 AM
11/17/11 12:01 AM
Houston Texas
Houston Texas
Hard for anyone to see when you are smiling and cruising down the road...
Re: Parking brake mechanism 70 Cuda something missing here? [Re: PAINT IT BLACK] #1113807
11/18/11 12:48 PM
11/18/11 12:48 PM
super gas
super gas
Actually both those pictures are mine. I did both those units.
Jules
Re: Parking brake mechanism 70 Cuda something missing here? [Re: PAINT IT BLACK] #1113808
11/18/11 01:10 PM
11/18/11 01:10 PM
Houston, Tx
hemi68charger Offline
Houston, Tx
So,, what you are saying is that you can ACTUALLY drive one of your cars now to a club function?
Club's Christmas Dinner is coming up soon there Mister at the museum, no excuses........
Troy
Houston Mopar Connection Club
Re: Parking brake mechanism 70 Cuda something missing here? [Re: hemi68charger] #1113809
11/18/11 01:22 PM
11/18/11 01:22 PM
Houston Texas
Houston Texas
I'm trying. And where have YOU been Troy??? Don't you know I could use the help of a seasoned pro from the Houston area???? You need to come see my lift anyhow.
Re: Parking brake mechanism 70 Cuda something missing here? [Re: JulesdaWiperman] #1113810
11/18/11 01:23 PM
11/18/11 01:23 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Jules
Yeah but there are three pictures...
Re: Parking brake mechanism 70 Cuda something missing here? [Re: PAINT IT BLACK] #1113811
11/18/11 01:30 PM
11/18/11 01:30 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
IF should you go looking for one, be warned it's a 1970 E-body only lever assy
1971 E-boy attaches to the cable differently
1970 B-body has a different style pedal arm
Re: Parking brake mechanism 70 Cuda something missing here? [Re: gtx6970] #1113812
11/18/11 05:37 PM
11/18/11 05:37 PM
Houston Texas
Houston Texas
Good to know. But I can weld/fab and this one is definitely fixable.
By the way Bill, I found some extra firewall nails and I made a pretty cool grommet for the release handle. Worked really well.
