Page 2 of 4 1 2 3 4
Re: A-833 4 speed racers...Setup? [Re: 68LAR] #1113648
11/19/11 11:58 AM
11/19/11 11:58 AM
sweden
sshemi Offline
sshemi  Offline
sweden
Seeing as how my son started this post I'll drop my combo for all to scrutinize.
engine 446 ci big block
car 68 Roadrunner
weight 3926 with me in the seat
Trans is stock 23 spline A833 no mods.
trans fluid ATF dextron
Launch rpm 49-5600 rpm depending on track conditions.
shift 6400 rpm
trap rpm 6300
slick pressure anywhere from 15 - 19 psi
rear gear 4.56 Dana
Clutch is Center Force Dual Friction 11" with aluminum flywheel (13 pounds)
best et and mph is signature
Is it your clutch or tires that slip?
Re: A-833 4 speed racers...Setup? [Re: sshemi] #1113649
11/19/11 12:03 PM
11/19/11 12:03 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
6,000 rpm launches, are you guys racing or having a burn out contest down the quarter mile track?
Re: A-833 4 speed racers...Setup? [Re: sshemi] #1113650
11/19/11 12:13 PM
11/19/11 12:13 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
Tires. My 60's suffer a little, but I don't have to change a clutch system every year. It's my choice. Something has to slip, I choose tires. My 60's are around 1.60.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: A-833 4 speed racers...Setup? [Re: 68LAR] #1113651
11/21/11 10:14 AM
11/21/11 10:14 AM
...gently down the stream
LAR_414 Offline OP
LAR_414  Offline OP
My clutch locks on the launch,... tires spin for about a car length. Still enough to lift the front tires off the ground and pull down 1.60 60' times.
So you can dump the clutch at 6k and not burn tire all the way down the track!
Can't do this on the street though!
Re: A-833 4 speed racers...Setup? [Re: LAR_414] #1113652
04/11/12 11:56 PM
04/11/12 11:56 PM
Toronto
mshred Offline
mshred  Offline
Toronto
Just thought about this thread again after starting the thread on tricks to help with transmission strength/ life
Definitely has to be more than what is posted...
Re: A-833 4 speed racers...Setup? [Re: mshred] #1113653
04/12/12 03:00 AM
04/12/12 03:00 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
No one is mentioning what gear set they are running? The 23 spline has a narrow, standard, wide and overdrive gears.
I have a 2.47-1 and a standard 2.66-1 and working on getting good parts together for a 3.09-1 box.
Does anyone know if the OD input shaft is the same as a standard 3.09-1? They are both 22 tooth...Tim
Re: A-833 4 speed racers...Setup? [Re: astjp2] #1113654
04/12/12 03:31 AM
04/12/12 03:31 AM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Astjp2: Thanks for posting that about the 3.09's
I did talk to one guy using the 3.09 and he said he had some issues hooking up (class rule, stock-type tires only).
Has anyone has ever tried going the wide-ratio 3.09, 1.67, 1.0 route?
Kind of like this car.
Mo' Farts
Moderated by "tbagger".
Re: A-833 4 speed racers...Setup? [Re: astjp2] #1113655
04/12/12 03:33 AM
04/12/12 03:33 AM
San Francisco Ca
SCATPK Offline
SCATPK  Offline
San Francisco Ca
Here is my setup.
68 ply gtx
original 18 spline trans
354 rear gear
325/50-15 et radials
mcleod street twin clutch about 4 years old
90wt fluid in trans
stock bellhousing
hurst comp+ shifter [originaly inland shifter]
modified shift levers to shorten throw
launch at 3000 rpm anymore and spins the tires
not powershifting. I know it would do much better if I did.
best 60ft 1.81
average 60ft 1.9`s need more time at the track and some nice sticky bias ply et street tires.
best et 11.81 @ 119.26
suspension has front and rear sway bars, bilstein shocks, big torsion/strut rods and factory rear leaf springs.
weight with my 180lbs in the front seat 4,120lbs
And I agree there are not to many guys that will play with an old manual trans at the track
Here is a run a couple of years ago.
http://youtu.be/N-EwO2XCvIM
Re: A-833 4 speed racers...Setup? [Re: SCATPK] #1113656
04/12/12 03:58 AM
04/12/12 03:58 AM
sweden
sshemi Offline
sshemi  Offline
sweden
I cant see how anyone would want the 3.09 ratio gears.
Too much rpm drop when going to second gear.
Re: A-833 4 speed racers...Setup? [Re: sshemi] #1113657
04/12/12 08:53 AM
04/12/12 08:53 AM
LAR_414 Offline OP
LAR_414  Offline OP
I run stock 2.66 gearset.
My dad tried the old 3.09 set and broke two input shafts. Actually took the teeth off of one and twisted the splines on another one. We think that the metal is just not as good as the later setups. Either way, the 3.09 gears from the mid 60's A-body transmissions are not up to snuff, strength wise.
Re: A-833 4 speed racers...Setup? [Re: LAR_414] #1113658
04/12/12 12:48 PM
04/12/12 12:48 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Thats interesting, the mopar performance chassis manual recommends the 3.09 for drag racing. Al Debevec told me about using the 3.09 gears over the 2.66 because high torque motors wanted the rpm change. Tim
Re: A-833 4 speed racers...Setup? [Re: 68LAR] #1113659
04/12/12 01:34 PM
04/12/12 01:34 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
rear gear 4.56 Dana
You gave everything except the tire size. What size are the tires in your Avatar Puicture? Do they spin much at launch?
thanks
Old Geezer Racing
Re: A-833 4 speed racers...Setup? [Re: SCATPACK 1] #1113660
04/12/12 01:49 PM
04/12/12 01:49 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
Tires in my avatar pic are for cosmetic purposes only. (P345/55R15) I blow them off at will on the street if I jump on it. At the track I use 29 12.50 X 15 Hooser slicks. Tires spin about 5 feet at launch.
As stated, I've tried the 3.09 gear set. It didn't work for me. My short times were the same as the 2.66 set. My ET's were also about the same. I twisted 2 3.09 input shafts and actually wiped out the cluster gear with the last twist...
My car being heavy, I thought the 3.09 set would work real well. In my case it didn't, so I'm sticking with the 2.66 low gear set.
Re: A-833 4 speed racers...Setup? [Re: 68LAR] #1113661
04/12/12 01:58 PM
04/12/12 01:58 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I wonder if cryogenically treating the gears would help. Tim
Re: A-833 4 speed racers...Setup? [Re: astjp2] #1113662
04/12/12 02:08 PM
04/12/12 02:08 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
What gearset does a 68-70 B-body 23 spline use ?
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: A-833 4 speed racers...Setup? [Re: AlexP] #1113663
04/12/12 02:13 PM
04/12/12 02:13 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
2.66-1
Re: A-833 4 speed racers...Setup? [Re: astjp2] #1113664
04/12/12 03:15 PM
04/12/12 03:15 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
The late coarse pitch overdrive input is the same as the old 3.09 input but the '75-7 overdrive input is different.
Re: A-833 4 speed racers...Setup? [Re: 446acuda] #1113665
04/12/12 03:29 PM
04/12/12 03:29 PM
sweden
sshemi Offline
sshemi  Offline
sweden
Seriosly who would want an rpm drop from 7000 to 4300???
Re: A-833 4 speed racers...Setup? [Re: sshemi] #1113666
04/12/12 04:03 PM
04/12/12 04:03 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
This is about the 1:1 3.09 A833 that has 3.09 first, 1.92 second, 1.40 third and 1:1 fourth. Not much different than the ratios you would find in a Jerico or G-force drag race transmission.
Re: A-833 4 speed racers...Setup? [Re: LAR_414] #1113667
04/12/12 06:07 PM
04/12/12 06:07 PM
ca
brownout Offline
brownout  Offline
ca
There is a bunch of great info in this post. I will share my combo even though I am trying to get it dialed in still. Mainly a street car but it sees the track a lot too.
70 cuda with a 493 not sure of the weight
23 spline transmission
80w90 gear oil
best pass launched at 3700 spinning the tires
m/t 275/60 drag radials
shifting at 6200 (not powershifting)
mcleod single disk 11.95
3.23 gears stock suspension ran 12.55 @ 111
Now have some homemade caltracs and stock springs put 3.91s in
We will see what happens my 60 ft is horrible. I am shooting for 12.20-.30s
-Cody
Page 2 of 4 1 2 3 4
