Difference between 318 and 340 main caps? #1112667
11/13/11 02:16 PM
11/13/11 02:16 PM
NC
alpha727 Offline OP
alpha727  Offline OP
NC
I've got a 340 block with no main caps. Can I pull a set from a 318 and run them on the 340?
Re: Difference between 318 and 340 main caps? [Re: alpha727] #1112668
11/13/11 02:32 PM
11/13/11 02:32 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
340 caps are a little beefier and taller than 318 caps but either will fit. And of course line boring will be required. Here's my post from last year:
https://board.moparts.org/ubbthreads/show...rue#Post6304938
Re: Difference between 318 and 340 main caps? [Re: alpha727] #1112669
11/13/11 02:33 PM
11/13/11 02:33 PM
The Sunny Shuswap
dodgefarmer Offline
dodgefarmer  Offline
The Sunny Shuswap
They will bolt in but I doubt that they will line up.
Randy
Re: Difference between 318 and 340 main caps? [Re: dodgefarmer] #1112670
11/13/11 02:53 PM
11/13/11 02:53 PM
yes have your machine shop check that they're concentric. May need to line bore or hone
Re: Difference between 318 and 340 main caps? [Re: RapidRobert] #1112671
11/13/11 03:09 PM
11/13/11 03:09 PM
NC
alpha727 Offline OP
alpha727  Offline OP
NC
Re: Difference between 318 and 340 main caps? [Re: RapidRobert] #1112672
11/13/11 05:11 PM
11/13/11 05:11 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
yes have your machine shop check that they're concentric. YOU WILL need to line bore or hone
Fixed it for you
Re: Difference between 318 and 340 main caps? [Re: HotRodDave] #1112673
11/13/11 05:43 PM
11/13/11 05:43 PM
Fixed it for you
It's always nice to have friends
