the trucks got 8 3/4 up to 74 with the 5 on 4.5 wheel bolt pattern
4x4 8 3/4 would have the 5 on 5.5 wbp
i have a 72 4x4 truck 8 3/4 housing that had a 489 3.92sg with the 5 on 5.5 wbp
i have a set of c-body car axles that fit with the 5 on 4.5 to fit an eaily 2x and 4x4 with sbp
most likely swaped in to match the wbp
look to see if it is a c-body 8 3/4 that has had the perches moved to the 43" centers
![](/ubbthreads/images/graemlins/scope.gif)
make sure the gear in the 8 3/4 matches the front before running it,most likly does but I have had mixed matched gears to stay mobile.
yes,the range box is killer for a double set up
![](/ubbthreads/images/graemlins/thumbs.gif)
it is kool to know that a truck and c-body 8 3/4 share the same axles and housing widths..it can be used in early trucks or mid 80s truck with the stock wbp
![](/ubbthreads/images/graemlins/boogie.gif)
oh and the A-body 8 3/4 BOLTS in to a truck on the same 43" perch centers to tuck 12s and 29x15x15 M/Ts
![](/ubbthreads/images/graemlins/whistling.gif)
