Re: Gas Additives-Do you have first hand experience?
[Re: Mopar Grandpa]
#1112603
11/13/11 11:54 AM
11/13/11 11:54 AM
RapidRobert
fast idle in your driveway & slowly pour several ounces of diesel fuel in the carb & when your almost empty dump the last bit in to drown it & let it sit overnight then pull/clean the plugs so you can start it then take it out on the hiway & romp on it & may need to clean the plugs again when you are done. Seafoam would work also & save you the trouble of buying that small amt of diesel at a diesel pump
[Re: RapidRobert]
#1112604
11/13/11 12:00 PM
11/13/11 12:00 PM
Posts: 15,487 Florida
scratchnfotraction
x2 on seafoam trickle down the carb 3/4 can,dump the rest as engine shuts down,let sit,then run engine. it will smoke very heavy for a bit but will stop in a bit,may want to change plugs after its done. IIRC,thats what the directions on the can say,or add to tank of gas to do the samething while it lubes the upper engine,just takes longer.
[Re: Mopar Grandpa]
#1112608
11/14/11 02:17 PM
11/14/11 02:17 PM
Posts: 9,336 South-Central (Sebring), FL
Commando1
Okay, for those of you that have used Seafoam, or any other product, have you pulled your intake and/or heads to actually see if the product worked as advertised? Was everything pretty well cleaned up?
You want to talk about Mazda rotary engines and their carbonized seals and how Seafoam is the best and proven way to decarbonize them? AMHIK (thanks to a very helpful Moparts member).
[Re: Mopar Grandpa]
#1112610
11/15/11 10:46 AM
11/15/11 10:46 AM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
Back around 1998 I soaked eight 1994 Magnum 5.9L pistons in Chevron Techron (not the current 'Plus' version of today), Redline SI1, Liqui-Moly Ventril Sauber (means valve cleaner in German), Liqui-Moly Jectron, Chrysler ATF+2, Aircraft Paint Remover, 70% Walgreens propanol rubbing alcohol, and Chevron Regular gasoline (not 10% ethanol back then) The Libui-moly Ventril Sauber http://www.liqui-moly.de/liquimoly/produktdb.nsf/id/en_1014.html?Opendocument&land=DE did the best job removing carbon from the piston tops during my soak, and Chevron Techron did second best, but both took over two weeks to really remove 95% of the deposits. The Liqui-Moly products used to be in stock at VW and BMW dealerships, and some auto parts stores in NC at least. They were about 50% higher priced than Chevron back then. the expensive Yamaha 'Ring Free' is supposed to be specially designed for this job too: http://www.yamaha-motor.com/outboard/apparel/apscitemdetail/3/145/all/1/10007/detail.aspxI also tried taking a second PCV valve and sucking the condensate water from the Ram's air conditioner system drain and injecting it into the intake through the 'test port' nipple on the driver's side of the 'Beer Barrel' factory Magnum intake. This 'poor man's water injection' seemed to clean up carbon deposits, reduce full throttle pinging ... but it hurt city driving MPG by about 2 MPG during the time I tried it, which was about 3 months. It also caused a noise that could be hear inside the pickup when the radio was off. A $8 bottle of official Chrysler Combustion Chamber cleaner is a good manual de-carbonizer, and appears to be a brown foam at least partly made of water. I would rate Chrysler CCC as superior to Sea Foam. Some years ago I read about a solvent for soaking aircraft engine used pistons to remove carbon deposits, but I cannot find the link to the magazine article now. This solvent was alleged to do a very good job in less than a day of soaking.
[Re: 360view]
#1112611
09/14/12 12:03 PM
09/14/12 12:03 PM
Posts: 3,533 Indiana
Fury Fan
Indiana
If soaking, why not use good 'ole carburetor cleaner (the soaking type, not the aerosol)? And what would happen if *that* was poured down the carb? Personally, IMHO there's always a layer of carbon in there, and if it's just a dust-coating leave it be. If it's big chunks you'd want them gone, but then there's the risk of where they'd go. And BTW - kerosene could be used instead of diesel?
Parts I seek:
driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set
16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better.
69-73 C-body caliper brackets and/or splashields
Send a PM.
[Re: Fury Fan]
#1112612
09/15/12 01:57 AM
09/15/12 01:57 AM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
Very soon after treating it will look the same as it does now. Why bother?
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: Mopar Grandpa]
#1112614
09/15/12 10:19 AM
09/15/12 10:19 AM
Posts: 12,187 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
This question comes up ever so often and the most obvious and proven product is overlooked. Most every outboard motor shop has de-carbonate products that are made for this and really work well.
Heck, even GM has a version of the same product called Upper Cylinder Cleaner. Most other manufacturers probably do too.
2 stroke engines used to have real problems with ring sticking due to carbon build up. They needed a product that worked. So for decades these products have been around. In fact, most outboard service schools recommend these products for use as a carb cleaner. The OMC stuff is all I have used as a carb cleaner for 25 years
It is available as a pour in can or in aerosol form. It is very gentle on aluminum and such, is water soluable and works by molecularly de-constructing the hydrocarbon links. It is not a corrosive.
I am surprised that something like this that works so well is often overlooked. It is designed for the very job of cleaning intake tracts and combustion chambers and works better than anything else.
Just saying.
Master, again and still
[Re: 360view]
#1112616
09/17/12 09:19 PM
09/17/12 09:19 PM
Posts: 238 Florida, US
72ls5fla
Florida, US
I have a strange one for ya - but it really works ....
If you buy a bag of small fine rice (hard stuff, not add watter and PUFF type) and very slowly feed it through the carb while running around 1500-2000 RPM, it will literally "blast" the inside of the combustion chambers clean.
Then follow up with a FOG of Sea-Foam, you get a great cleaning.
I did this and busted loose 10 years of crap out the back ...
You will need to change the oil and filter immediately following this.
I thought the old (ancient) guy was crazy that told me this - he is an old school mechanic from when they invented cars.. LOL
but - it worked.
Crazy I know - but a true thing.
Bill
