Torch trouble #1112596
11/13/11 11:43 AM
11/13/11 11:43 AM
Lost and Spaced
bboogieart Offline OP
Lost and Spaced
I know this is tool related and not mopar per say but....
I was cutting up a frame for parts and all of a sudden I had no pressure from the oxygen to blow out the slag. Still get a nice flame but no blow through.
The tank reads about half full, is that not enough to give me my cutting pressure? 35# to cut. Or is there something I am missing?
I have mechanical Aptitude.
I can screw up anything.
Re: Torch trouble [Re: bboogieart] #1112597
11/13/11 11:47 AM
11/13/11 11:47 AM
If you are cutting up a Mopar frame (truck?) then it's Mopar related . You have ox to the handle just not extra ox for cutting right? I'd take apart the handle & fix the blockage
Re: Torch trouble [Re: bboogieart] #1112598
11/13/11 11:48 AM
11/13/11 11:48 AM
Texas
70Runnerdude Offline
Texas
If the oxygen tank is half full like you say then it sounds like you have a regulator problem.
Re: Torch trouble [Re: bboogieart] #1112599
11/13/11 11:49 AM
11/13/11 11:49 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
What's the tip look like? maybe you got slag and dirt plugging up the middle hole? (I think it's the middle hole the oxygen shoots out of to blow away the slag)
I know my torch is not cutting very well anymore, it more or less just melts a wide channel through the steel, because my tip is shot and needs replaced.
**Photobucket sucks**
Re: Torch trouble [Re: 70Cuda383] #1112600
11/13/11 12:13 PM
11/13/11 12:13 PM
Lost and Spaced
Lost and Spaced
Thanx guys,
I was planning to go clean it up today, it was getting late and this just made me want to do any thing else. Looks like I need to open it up and do some cleaning. Hope it is that simple. Heading out there now.
I think the regulators are fine, as I get a goood flame just no blow through.
As for it being mopar related, most of my problems are.
Not a truck frame but a c body front stub. Same diff, huh?
Re: Torch trouble [Re: bboogieart] #1112601
11/13/11 06:20 PM
11/13/11 06:20 PM
Lost and Spaced
Lost and Spaced
Turns out I got some crud in the tip. Didn't se it last night but it's cutting now.
Again thanx for all the help.
