a nice intake and carb for my built up 440 #111208
08/27/08 03:54 PM
08/27/08 03:54 PM
ME
79machocharger Offline OP
ME
My motor is almost done and I was looking for a nice combo intake and carb to put on it. I still want to be able to shut my hood on my 69 charger with out it hitting my air cleaner. I'm not sure of the specs on the motor but it is bult and will probably have around 450 hp.
Re: a nice intake and carb for my built up 440 [Re: 79machocharger] #111209
08/27/08 04:10 PM
08/27/08 04:10 PM
CT USA
N
Nick Mineau Offline
Nick Mineau  Offline
N
CT USA
its hard to say with no specs. but for 450 horsepower 440 i would run a performer rpm with a edelbrock 750 carb. if its more on the 400 horse side run a ch4b.
Re: a nice intake and carb for my built up 440 [Re: Nick Mineau] #111210
08/27/08 05:11 PM
08/27/08 05:11 PM
Rohnert Park, Ca
ryan053 Offline
ryan053  Offline
Rohnert Park, Ca
you will need to get a drop base air filter. im not sure how much of a drop but i need to get one for my 383 with an rpm intake for my 68 charger.
Re: a nice intake and carb for my built up 440 [Re: ryan053] #111211
08/27/08 05:51 PM
08/27/08 05:51 PM
dogdays Offline
dogdays  Offline
As the Edelbrock 750s have been known to have problems that are more than simple to work through, I would suggest an Edelbrock 800. They don't seem to have the same kinds of problems. the Thunder series AVS carbs while expensive seem to really work well.
R.
Re: a nice intake and carb for my built up 440 [Re: dogdays] #111212
08/27/08 05:58 PM
08/27/08 05:58 PM
Riverside, Ca
R70RUNNER Offline
R70RUNNER  Offline
Riverside, Ca
Mild street build, it's hard to beat a Eddy Thunder, I've run both 650 and 800's The carbs just plain work. On more agressive cams where the vacuum signal is weak Holleys are a better choice. Really like the Eddy RPM or if you need just a bit more hood clearance try a Holley Street Dominator intake.
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
Re: a nice intake and carb for my built up 440 [Re: R70RUNNER] #111213
08/27/08 06:01 PM
08/27/08 06:01 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Holley 750 carb, w/ vacuum secondaries or a DP.
For intake, edelbrock RPM would work great but require you to run a drop-base air cleaner. Holley Street Dominator would work well if you have at least 3.55 or numerically higher gears.
Re: a nice intake and carb for my built up 440 [Re: DaytonaTurbo] #111214
08/27/08 09:52 PM
08/27/08 09:52 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I run the Holley Street Dominator with a Holley 850 DP on my 440 that makes about 500 flywheel HP. I have a 1" spacer on it and it fits under my flat hood with no problems. I like the Performer RPM and the Holley Street Dominator alot for mild street/strip bigblocks. But the RPM is higher and wont clear some flat hoods so I went with the Holley SD and the 850 DP and I love it as they work great for me. Ron
Re: a nice intake and carb for my built up 440 [Re: 383man] #111215
08/28/08 08:27 AM
08/28/08 08:27 AM
ME
ME
Any one have the part #'s for the holley SD and the holley 850 carb. I think I'll go that route as I dont want to have any cleance issues. I also want to try the holley carb and intake out as I've gone with edelbrock in the past and want to change it up and try something different. Thanks so much guys for all your help.
Re: a nice intake and carb for my built up 440 [Re: 79machocharger] #111216
08/28/08 08:37 AM
08/28/08 08:37 AM
ME
ME
Do they still make the holley street dominator or am I going to have to find a used one. Also I cant seem to find a holley 850 dp? Where's the best place to look for one?
Re: a nice intake and carb for my built up 440 [Re: 79machocharger] #111217
08/28/08 08:45 AM
08/28/08 08:45 AM
Farmland, IN
Ludington1 Offline
Ludington1  Offline
Farmland, IN
Hi Ryan,
Here's the Street Dominator
Darren
Re: a nice intake and carb for my built up 440 [Re: Ludington1] #111218
08/28/08 08:53 AM
08/28/08 08:53 AM
ME
ME
Cool, thanks Darren. I just found the carb, does this seem like a decent price for it?
http://chucker54.stores.yahoo.net/dopumo41ca.html
Re: a nice intake and carb for my built up 440 [Re: 79machocharger] #111219
08/28/08 08:57 AM
08/28/08 08:57 AM
ME
ME
Also should go with the 750 holley or the 800 with 450hp?
Re: a nice intake and carb for my built up 440 [Re: 79machocharger] #111220
08/28/08 09:27 AM
08/28/08 09:27 AM
The 750 will be snappier on the lowend and the 850 will run better up top. Either will work well if tuned properly.
Whoops just saw that you said 800 not 850.The 800 would probably be a good compromise .
Re: a nice intake and carb for my built up 440 #111221
08/28/08 10:11 AM
08/28/08 10:11 AM
ME
ME
I probably go with the 800 then, thanks, Ryan
