Carter AVS Problem
#111174
08/27/08 03:27 PM
08/27/08 03:27 PM
Posts: 2,640 Port Reading, NJ
roadrunner7070
Port Reading, NJ
On my 70 Roadrunner the original which I recently had rebuilt Carter AVS doesn't seem to be opening the secondaries. I had the car in the tranny place for him to set the kickdown linkage and he remarked to me that something doesn't appear to be right with the motor. It is not a tranny problem he says. The tranny kicks down but the car will not seem to go past 70 mph till I let up off the gas when I am in kickdown mode. My mechanic looked at it and did some tinkering and said the secondaries on stand still seem to be opening but after driving it there is just no power at kickdown. So he now thinks the secondaries are not opening. You don't get that massive pull from the motor. Everything is new. My mechanic said he was going to do a fuel pressure test to rule out the fuel pump. With 3:55 gears and the motor bored 30 over you would thing that I could at least squeel the tires but no luck. What should I be looking for or checking?
Re: Carter AVS Problem
[Re: 69Cuda340S]
#111176
08/27/08 03:48 PM
08/27/08 03:48 PM
roadrunner7070
Port Reading, NJ
With the hood open and air cleaner off you should be able to blip the throttle with it running and see the secondary air valve open up. Make sure its not too tight. Checking for lack of fuel flow is a good ideal too.
But will you be able to tell if they are opening fully? I believe this carb has manual secondaries.
[Re: roadrunner7070]
#111177
08/27/08 03:56 PM
08/27/08 03:56 PM
Posts: 75,094 A Banana Republic near you.
JohnRR
yes the carb has manual secondaries and it's easy to tell if they open all the way , there is a spring on the linkage on the pass side of the carb and if they are hitting something the primaries will open fully but not the secondaries .
[Re: 69Cuda340S]
#111178
08/27/08 04:00 PM
08/27/08 04:00 PM
Posts: 4,999 North Pole,New York
formula_s
North Pole,New York
JUST BE SURE TO STAND BY THE SIDE IF THE CAR WHEN PERFORMING THIS TEST,NOT IN FRONT OF IT.
#111182
08/27/08 05:31 PM
08/27/08 05:31 PM
Posts: 3,333 MARYLAND
69Cuda340S
MARYLAND
You will see the Secondary Air Valve flip open if its working correctly.
#111186
10/12/08 08:58 PM
10/12/08 08:58 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
Well I played around with the secondary valve and adjusted it for 2 turns counterclockwise and no secondaries. Then I loosened it up 1 turn and still no secondaries opening. What is the deal with this factory carb. Were these AVS carbs junk to begin with? Looks like after all these years and even being totally rebuilt I am going to have to junk it and go with an Edelbrock.
Where do you think the Edelbrock originated ? ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
[Re: 62maxwgn]
#111187
10/12/08 09:26 PM
10/12/08 09:26 PM
Posts: 1,668 Mi,U.S.A.
mike s
Mi,U.S.A.
Anyone adjust the throttle cable?
Leave the gun.......take the Cannoli's....Mike
[Re: mike s]
#111188
10/12/08 09:33 PM
10/12/08 09:33 PM
roadrunner7070
Port Reading, NJ
No. Not since I put the new one on when I finished restoring the car. I even took the car back to the tranny guy to set the kickdown lever and he was the first to notice there was something wrong with the carb.
[Re: 62maxwgn]
#111189
10/12/08 09:37 PM
10/12/08 09:37 PM
roadrunner7070
Port Reading, NJ
Difference is the old rebuilt carb is 38 years old and is not always going to work correctly and the new Edelbrock should work with no problem right out of the box.
#111192
10/12/08 10:14 PM
10/12/08 10:14 PM
RapidRobert
just push down on the secondary air valve & see if it will open, shouldn't take much then loosen the screw/button for the thin coil spring that holds it closed & get it as loose as you want then take it out & your secondaries will open & you'll know if that is the problem. Have it warmed up as mentioned there is an interlock.
