Re: Easy 904 question
[Re: WheelsUp73]
#1111525
11/11/11 09:21 PM
11/11/11 09:21 PM
Posts: 5,207 Menomonee Falls
DemonDust
Menomonee Falls
It should be set up from .060 to .070
I'm using my thinnest ring. So is .055 to tight? Will it cause problems?
[Re: DemonDust]
#1111526
11/11/11 09:28 PM
11/11/11 09:28 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
I don't think you will see a problem with .055
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: DemonDust]
#1111530
11/13/11 05:40 PM
11/13/11 05:40 PM
Posts: 25,951 Rio Linda, CA
John_Kunkel
Rio Linda, CA
An easy way to pick up a little clearance is to thin the pressure plate in a lathe.
[Re: John_Kunkel]
#1111532
11/13/11 06:28 PM
11/13/11 06:28 PM
Posts: 30,474 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
An easy way to pick up a little clearance is to thin the plessure plate in a lathe.
Is that a PLEASURE plate ?.... I wood like to have one of those ...
[Re: dOc !]
#1111533
11/13/11 07:54 PM
11/13/11 07:54 PM
Posts: 20,662 in a cattle trailer down by th...
Guitar Jones
I've heard you already have one.
[Re: Guitar Jones]
#1111534
11/13/11 08:12 PM
11/13/11 08:12 PM
dOc !
Florida STAYcation
You heard wrongO ... how is yours wurking ? ... even-though it is an IMport !
[Re: dOc !]
#1111536
11/14/11 04:47 PM
11/14/11 04:47 PM
Guitar Jones
Got a whammy bar too.
