Re: Shortening a driveshaft yourself
[Re: JohnRR]
#1111428
11/12/11 10:37 AM
11/12/11 10:37 AM
Posts: 15,487 Florida
scratchnfotraction
Has anyone tried this driveshaft kit? I've been thinking of doing that for my small to big block conversion.
Driveshaft kit from Mancini's
That was never balanced to begin with so I doubt it would even be close ...
But it seems the overwhelming response is to just weld it up an go ...
I guess we can put driveline shops right up there with automotive machine shops , balancing is just another money grab ...
not me..I have had it come out at 105 mph on I-75,it was out of balance/out of phase/home cut/weld..machine shop said it looked to have bent in the middle and then broke a u-joint/yoke weld.
speculating here,but seems thats what happend,vib from the git go and got worse at speed,let off and BANG!!
not to mention 2 mufflers,3 feet of exhast pipe,1 rear shock and one hell of a bang.
I will just keep my local shop in bizness,cuttin and balanceing my junk.
cant see puting 3-4-5 K into and engine and risk the balance on it myself,but then again i run used junk most of the time antways..but it does have the factory balance
do you feel lucky?..good luck with it?
seems a lot of guys get away with it,I did for a while,cost more in the long run though
[Re: larrymopar360]
#1111432
11/12/11 05:56 PM
11/12/11 05:56 PM
Posts: 10,982 North Dakota
6PakBee
North Dakota
I've never had a driveshaft shortened but having Dodge trucks with driveshaft splines I've had more than one spline replaced. Always had them balanced. One time the shop screwed up the phasing and I got a fairly bad vibration from it. Took it back to the shop, they cut it open again, rewelded it, and life was good. No balance the second time through. My conclusion? Phasing is more important than balance.
[Re: 6PakBee]
#1111433
11/12/11 10:13 PM
11/12/11 10:13 PM
Posts: 20,384 Park Forest, IL
slantzilla
Park Forest, IL
For the record, the shaft in my Valiant was cut and rebalanced by a driveline shop. However, I've seen a ton of Mopars (mostly 4 speeds) toss the factory driveshaft through the floor in the traps. That's right, all original Ma Mopar driveshafts will break too. The balance job on many of them was nothing to write home about when they were new. Would I cut my own now? Sure. But, I also have access to a lathe and mig welder now.
[Re: Finoke]
#1111435
11/12/11 10:51 PM
11/12/11 10:51 PM
dartman366
Mt. Vernon, Ohio
That's the very same kit that has been in my race car since 1993 and has held up well,,,and yes it was balanced after it was cut to length and welded.
[Re: dartman366]
#1111436
11/12/11 10:55 PM
11/12/11 10:55 PM
I have a local shop that shortens, balances, and puts in new spicer joints for under $140.00.
Turnaround is usually one working day.
I'm big on doing things myself but sometimes you just gotta hire the experts with the proper equipment.
[Re: slantzilla]
#1111437
11/12/11 10:56 PM
11/12/11 10:56 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
I was watching the speed channel last weekend and I think it was Trucks! they had on where they cut a driveshaft with a sawzall and wire welded the yoke. Scary how they glossed over checking phasing or anything else.
[Re: dartman366]
#1111439
11/14/11 11:42 PM
11/14/11 11:42 PM
Posts: 4,108 Horsham, Pa.
Finoke
Horsham, Pa.
that is good to hear. Thanks
[Re: Finoke]
#1111440
11/16/11 12:51 AM
11/16/11 12:51 AM
Posts: 8,089 Sorrento, BC, Canada
4speeds4me
I've done quite a few myself with never an issue. That said, if I had a vibration or something didn't feel or look right, I wouldn't hesitate to have it gone over. If it's phased correctly and you've verified that the yoke is square in there, there is no reason you can weld it as well as a shop (assuming you have reasonable skill in that department). Therefore the only thing you aren't equipped to do is balance, and if it's that far out, you'll take care of that anyways. My ...
2 Demons...no, not my kids!
[Re: bboogieart]
#1111442
11/16/11 01:20 PM
11/16/11 01:20 PM
Posts: 18,166 Mass
DAYCLONA
Mass
Unless you possess the skill and equipment to assemble/weld and balance a shaft, send it out , whats $100-$400 to have a shaft made/shorten/etc.... keep in mind "most" driveshaft shops are set up for the average Joe's daily driver, meaning their equipment for balancing is usually limited to 3500 RPM shaft speeds,...a performance oriented shop usually has equipment that takes a shaft up to 10,000 RPM, something to consider on a high RPM running car, or one equipped with an OD in the .64 to .50 range, prop speeds can get up there in the RPM range
[Re: DAYCLONA]
#1111443
11/16/11 04:06 PM
11/16/11 04:06 PM
Posts: 5,923 Athens, Greece
Pyper70
Athens, Greece
Didn't read the whole thing, maybe someone else said it...but for $100 bucks done correct by someone who does them all day along is money well spent. Imagine doing it yourself and then getting a stress fracture which circles around the whole driveshaft. If its the front yoke...how would you feel about catapulting your car on a public road, injuring yourself, other driver, or your car?
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
[Re: Pyper70]
#1111444
11/16/11 04:33 PM
11/16/11 04:33 PM
Posts: 75,324 A gulag near you.
JohnRR
A gulag near you.
That's what insurance is for ...
