Page 2 of 3 1 2 3
Re: Shortening a driveshaft yourself [Re: JohnRR] #1111428
11/12/11 11:37 AM
11/12/11 11:37 AM
scratchnfotraction Offline
Has anyone tried this driveshaft kit? I've been thinking of doing that for my small to big block conversion.
Driveshaft kit from Mancini's
That was never balanced to begin with so I doubt it would even be close ...
But it seems the overwhelming response is to just weld it up an go ...
I guess we can put driveline shops right up there with automotive machine shops , balancing is just another money grab ...
not me..I have had it come out at 105 mph on I-75,it was out of balance/out of phase/home cut/weld..machine shop said it looked to have bent in the middle and then broke a u-joint/yoke weld.
speculating here,but seems thats what happend,vib from the git go and got worse at speed,let off and BANG!!
not to mention 2 mufflers,3 feet of exhast pipe,1 rear shock and one hell of a bang.
I will just keep my local shop in bizness,cuttin and balanceing my junk.
cant see puting 3-4-5 K into and engine and risk the balance on it myself,but then again i run used junk most of the time antways..but it does have the factory balance
do you feel lucky?..good luck with it?
seems a lot of guys get away with it,I did for a while,cost more in the long run though
Re: Shortening a driveshaft yourself [Re: VITC_GTX] #1111429
11/12/11 12:18 PM
11/12/11 12:18 PM
Alaska
73rrak Offline
73rrak  Offline
Alaska
They just did this on that muscle car show on the " Power Block " That's on Saturday morning last week. It looked pretty simple and it looked like it worked . Buuuuuuuut I did know a guy that lost the front U-joint on his Chevy pick up. The driveline fell out and stabbed the ground it pole vaulted the truck #ss over tea kettle and they found him between the top of the dash and the roof of the cab squashed flatter than a fart. I think I'll keep paying the $100 for a cut, balance and new U-joints. It's money well spent.
Re: Shortening a driveshaft yourself [Re: scratchnfotraction] #1111430
11/12/11 06:26 PM
11/12/11 06:26 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
thats kinda getting back to "getting away with it" no?
the tube end does need a nice straight cut to seat the yoke and help phase it I would think.
Nope, being square has nothing to do with phasing and the yoke doesn't need to be fully seated as long as the center-to-center distance is the same on both sides...a little gap will just be filled with weld anyway.
I have done numerous driveshafts at home, on some of them I bought brand new end yokes and drove them into tubing that had been squared off in my lathe and never had a problem. Later on I found that this doesn't quarantee centers are equidistant...using a vernier to check the center distance often leaves a slight gap on one side before welding.
Re: Shortening a driveshaft yourself [Re: burdar] #1111431
11/12/11 06:37 PM
11/12/11 06:37 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
I had a driveshaft shortened at a metal fab shop once. What you described is exactly what they did. I never had it ballanced and didn't have any problems. Obviously the proper way is to have it ballanced. I'm sure I just got lucky.
Ditto for me, twice.
Facts are stubborn things.
Re: Shortening a driveshaft yourself [Re: larrymopar360] #1111432
11/12/11 06:56 PM
11/12/11 06:56 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I've never had a driveshaft shortened but having Dodge trucks with driveshaft splines I've had more than one spline replaced. Always had them balanced. One time the shop screwed up the phasing and I got a fairly bad vibration from it. Took it back to the shop, they cut it open again, rewelded it, and life was good. No balance the second time through. My conclusion? Phasing is more important than balance.
Re: Shortening a driveshaft yourself [Re: 6PakBee] #1111433
11/12/11 11:13 PM
11/12/11 11:13 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
For the record, the shaft in my Valiant was cut and rebalanced by a driveline shop.
However, I've seen a ton of Mopars (mostly 4 speeds) toss the factory driveshaft through the floor in the traps. That's right, all original Ma Mopar driveshafts will break too. The balance job on many of them was nothing to write home about when they were new.
Would I cut my own now? Sure. But, I also have access to a lathe and mig welder now.
Re: Shortening a driveshaft yourself [Re: John_Kunkel] #1111434
11/12/11 11:40 PM
11/12/11 11:40 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
The reality is that most driveshaft tubing isn't all that round so dial indicating is useless and the method of separating the tubing end is irrelevant as long as the end is reinstalled in phase and equidistant with the other.
Ok in 1968 I built an altered wheelbase 62 plymouth.
I cut the driveshasft with a pipe cutter removed 15". To assemble it and have it be perfectly straight I decided to find something to fit inside or outside to use as a jig. I found that an old school grease can which was made of a cardboard body with metal top and bottom was nearly a press fit. I had scratched a line to phase the joints before cutting so with my third time ever turning on a machine the welding began. It worked perfect and I still laugh at not knowing it could not work.
home of the
Sox and Martin Hemi Duster
Re: Shortening a driveshaft yourself [Re: Finoke] #1111435
11/12/11 11:51 PM
11/12/11 11:51 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
That's the very same kit that has been in my race car since 1993 and has held up well,,,and yes it was balanced after it was cut to length and welded.
Re: Shortening a driveshaft yourself [Re: dartman366] #1111436
11/12/11 11:55 PM
11/12/11 11:55 PM
I have a local shop that shortens, balances, and puts in new spicer joints for under $140.00.
Turnaround is usually one working day.
I'm big on doing things myself but sometimes you just gotta hire the experts with the proper equipment.
Re: Shortening a driveshaft yourself [Re: slantzilla] #1111437
11/12/11 11:56 PM
11/12/11 11:56 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I was watching the speed channel last weekend and I think it was Trucks! they had on where they cut a driveshaft with a sawzall and wire welded the yoke. Scary how they glossed over checking phasing or anything else.
Don't be the exception.
Re: Shortening a driveshaft yourself [Re: 73rrak] #1111438
11/13/11 12:02 AM
11/13/11 12:02 AM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I would love to know,, but do I dare ask?
Re: Shortening a driveshaft yourself [Re: dartman366] #1111439
11/15/11 12:42 AM
11/15/11 12:42 AM
Horsham, Pa.
Finoke Online content
Finoke  Online Content
Horsham, Pa.
that is good to hear. Thanks
Re: Shortening a driveshaft yourself [Re: Finoke] #1111440
11/16/11 01:51 AM
11/16/11 01:51 AM
Sorrento, BC, Canada
4speeds4me Offline
4speeds4me  Offline
I've done quite a few myself with never an issue. That said, if I had a vibration or something didn't feel or look right, I wouldn't hesitate to have it gone over. If it's phased correctly and you've verified that the yoke is square in there, there is no reason you can weld it as well as a shop (assuming you have reasonable skill in that department). Therefore the only thing you aren't equipped to do is balance, and if it's that far out, you'll take care of that anyways.
My ...
2 Demons...no, not my kids!
Re: Shortening a driveshaft yourself [Re: Supercuda] #1111441
11/16/11 11:03 AM
11/16/11 11:03 AM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
This is because these shows are hour long comercials and not intended to actually show you how things should be done right. Seems to me they spend more time telling how good the parts they used were.
As for drive shafts. I had one built by an implement shop. Asked the guy to ballance it. His response was it won't need it, as the new tube did not have a seem. Don't know about a seam in the stock shafts ( never saw one) but this one started to vibrate and got worse. I went to the junk yard and got the right one for my swap. (904 to 727) I don't listen to shop help any more and I find out what I need to know befor having anybody touch my stuff. I once had a mechanic tell me he wouldn't swap my gears in an old truck rear . I had another one I wanted to use for better mileage. His response was he could not do it cause one was posi and one was sure grip. I told him to go f&#% himself.
I have mechanical Aptitude.
I can screw up anything.
Re: Shortening a driveshaft yourself [Re: bboogieart] #1111442
11/16/11 02:20 PM
11/16/11 02:20 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Unless you possess the skill and equipment to assemble/weld and balance a shaft, send it out , whats $100-$400 to have a shaft made/shorten/etc....
keep in mind "most" driveshaft shops are set up for the average Joe's daily driver, meaning their equipment for balancing is usually limited to 3500 RPM shaft speeds,...a performance oriented shop usually has equipment that takes a shaft up to 10,000 RPM, something to consider on a high RPM running car, or one equipped with an OD in the .64 to .50 range, prop speeds can get up there in the RPM range
Re: Shortening a driveshaft yourself [Re: DAYCLONA] #1111443
11/16/11 05:06 PM
11/16/11 05:06 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
Didn't read the whole thing, maybe someone else said it...but for $100 bucks done correct by someone who does them all day along is money well spent. Imagine doing it yourself and then getting a stress fracture which circles around the whole driveshaft. If its the front yoke...how would you feel about catapulting your car on a public road, injuring yourself, other driver, or your car?
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Shortening a driveshaft yourself [Re: Pyper70] #1111444
11/16/11 05:33 PM
11/16/11 05:33 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
That's what insurance is for ...
Re: Shortening a driveshaft yourself [Re: Pyper70] #1111445
11/16/11 08:09 PM
11/16/11 08:09 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Imagine changing your own oil and leaving the drain plug loose.
Like the Clint said in the movie, "a man's gotta know his limitations".
Re: Shortening a driveshaft yourself [Re: John_Kunkel] #1111446
11/16/11 08:19 PM
11/16/11 08:19 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
You are comparing something that you do once maybe twice during the life of a car and something you should be doing monthly. If you can't tighten an oil pan bolt I hope you can see the stream of oil running down your driveway before you drive 2000 miles and have a booboo
Re: Shortening a driveshaft yourself [Re: JohnRR] #1111447
11/16/11 08:21 PM
11/16/11 08:21 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
The point is to not require insurance for something that could be accomplished for $100. The deductible you are going to pay for the insurance is probably 5x the price of sending the driveshaft out and a whole lot less of a headache later on
Page 2 of 3 1 2 3
