OK, first passes on the 408, guess the ET & MPH RESULTS
#1110278
11/09/11 06:00 PM
11/09/11 06:00 PM
Posts: 20,647 in a cattle trailer down by th...
Guitar Jones
Going out this Saturday, weather looks good, dry, high of 74 degrees.
360 based 408, stock block tall filled, 12.6:1, 276/284 @ .050, .698/.714 roller, W5's with 2.08/1.60, 230 cfm @ .700. M1 tunnel ram, 2 Demon 750's. H beams and Wiseco pistons. 2" headers with 4" collector 18" long
Low gear 904 with TA 4200 (stalled at 6000 in the driveway) converter, 4.86 8.75 rear, 14.5x32 tires @ 2650 race weight.
This is in a 2x3 chassis car, 4 link and struts.
I'll tell you now I don't plan on turning this thing more than 7500.
Re: OK, first passes on the 408, guess the ET and MPH
[Re: Performance Only]
#1110280
11/09/11 06:07 PM
11/09/11 06:07 PM
Guitar Jones
[Re: Quicktree]
#1110282
11/09/11 06:10 PM
11/09/11 06:10 PM
Guitar Jones
2650 is with me in it as it sits on the line. Maybe I should mention these are small chamber W5's with double quench pads, .032 piston to head.
[Re: Guitar Jones]
#1110283
11/09/11 06:19 PM
11/09/11 06:19 PM
Posts: 10,038 MN
JERICOGTX
MN
[Re: Brian Hafliger]
#1110285
11/09/11 06:30 PM
11/09/11 06:30 PM
Guitar Jones
I'd be happy with 9.70's. I also expect the track to be well prepped as this is a $100/car test session. If it's not I won't be the only unhappy camper they'll hear from I'm sure. I'm taking jets, drill bits, a timing light and other various and assorted utilities to dial this thing in. I aint wasting my $100.
#1110286
11/09/11 06:32 PM
11/09/11 06:32 PM
Quicktree
9.75 @ 137 mph
really? at 2650lbs should be way faster than that. do the heads really flow only [Email]230cfm@.700[/Email] ?
[Re: Quicktree]
#1110288
11/09/11 06:34 PM
11/09/11 06:34 PM
Guitar Jones
9.75 @ 137 mph
really? at 2650lbs should be way faster then that. do the heads really flow only [Email]230cfm@.700[/Email] ?
Yeah, there really isn't a lot of work in them. The chambers were opened up and the ports cleaned up really well. No CNC program or anything like that but my head porters bench is a little stingy too.
[Re: Guitar Jones]
#1110289
11/09/11 06:36 PM
11/09/11 06:36 PM
Quicktree
9.75 @ 137 mph
oh I see now, was thinking it was a typo.
[Re: Quicktree]
#1110290
11/09/11 06:41 PM
11/09/11 06:41 PM
Guitar Jones
9.75 @ 137 mph
The idea was to have enough motor to run 9.70's in the heat and not have to lean on it real hard so it would live until I can get a real block.
[Re: Guitar Jones]
#1110291
11/09/11 06:46 PM
11/09/11 06:46 PM
Quicktree
9.75 @ 137 mph
I don't know if you will get there. thats almost a half second gain. good luck
[Re: Quicktree]
#1110293
11/09/11 06:49 PM
11/09/11 06:49 PM
Guitar Jones
9.75 @ 137 mph
Yeah but that 363 was 15 years old, worn out, smoked and was just an MP shortblock to start with. It was a stop gap engine to get me through the last two races of a season and to the finals. It just never missed a beat so it lived there.
[Re: Guitar Jones]
#1110294
11/09/11 06:55 PM
11/09/11 06:55 PM
Guitar Jones
And you know what? I must be retarded, the heads flow 330 @ .700 not 230. What a dolt I am. I really shouldn't drink before noon.
[Re: Guitar Jones]
#1110296
11/09/11 07:06 PM
11/09/11 07:06 PM
Quicktree
And you know what? I must be retarded, the heads flow 330 @ .700 not 230. What a dolt I am. I really shouldn't drink before before noon.
I knew something was wrong with that picture. I think 9.60s are a given. with a better converter you could reach 50s or better imo. oh yea say a prayer for the rear.
