Re: Tricks of the Trade... [Re: sunroofgtx] #1110096
11/10/11 08:24 PM
11/10/11 08:24 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
Bring some for me too Mike! GLUG GLUG GLUG
Re: Tricks of the Trade... [Re: scatpacktom] #1110097
11/10/11 08:30 PM
11/10/11 08:30 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
You going?? I'm makin the trip..
MB
Re: Tricks of the Trade... [Re: F1Scamp] #1110098
11/10/11 08:56 PM
11/10/11 08:56 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
fart in the other drivers helmet
Re: Tricks of the Trade... [Re: HPMike] #1110099
11/10/11 08:57 PM
11/10/11 08:57 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
MB
Yep, I'm starting to feel better and so is the T/A. So I'm looking to take a pop at that 11.44 as well
https://board.moparts.org/ubbthreads/show...e=0#Post6910408
Re: Tricks of the Trade... [Re: 6bblRoadrunner] #1110100
11/10/11 09:08 PM
11/10/11 09:08 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
Check this out...
http://www.dvorakmachine.com/tech_LastMinuteHeroics.shtml
that was great.
Re: Tricks of the Trade... [Re: HPMike] #1110101
11/10/11 10:07 PM
11/10/11 10:07 PM
NY
F1Scamp Offline OP
F1Scamp  Offline OP
NY
Brian
I can get you two tenths. No tools needed. FAST legal 100%. If you are interested, give me a call......
MB
You messing with me Mike? I only have your shop number..
Work In Progress- 71' Duster F.A.S.T.- 10.36@130 Smallblock Record Holder.
Re: Tricks of the Trade... [Re: F1Scamp] #1110102
11/10/11 10:39 PM
11/10/11 10:39 PM
acworth / N. georgia - south e...
cheapstreetdustr Offline
have you tried putting an ignition retard module in it? retard the ignition timing 2*-3* after it shifts into high gear..
cheapst
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: Tricks of the Trade... [Re: cheapstreetdustr] #1110103
11/10/11 10:53 PM
11/10/11 10:53 PM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
Hope both you guys do well. Have fun and be safe.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
Re: Tricks of the Trade... [Re: F1Scamp] #1110104
11/10/11 11:22 PM
11/10/11 11:22 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Brian
MB
Nope, I'm serious
Leave the carb tune alone and call me tomorrow if you want..
MB
Re: Tricks of the Trade... [Re: fishy340] #1110105
11/10/11 11:53 PM
11/10/11 11:53 PM
Park Forest, IL
slantzilla Online content
slantzilla  Online Content
Park Forest, IL
Pack the front wheel bearings with STP. You'll have so little friction the wheels will turn for 5 minutes after you park the car.
Re: Tricks of the Trade... [Re: Rapid340] #1110106
11/11/11 10:09 AM
11/11/11 10:09 AM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
Thanks Jeff
Re: Tricks of the Trade... [Re: scatpacktom] #1110107
11/22/11 09:21 PM
11/22/11 09:21 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
Well did anything here help the cause?
Getting old just means you were smarter than some and luckier than others.
Re: Tricks of the Trade... [Re: dannysbee] #1110108
11/22/11 09:57 PM
11/22/11 09:57 PM
NY
F1Scamp Offline OP
F1Scamp  Offline OP
NY
The 0w oil didn't do anything but freak me out going down the track.
The 16v battery was worth something. I am assuming the alternator not working had something to do with it, though it seems to even idle better.
My homemade vacuum pump was worth something.
Tuning the carb was worth something.
Staging shallow made a huge difference.
Making the rear brakes stop dragging I am sure helped. Lowered the front and rear of the car over 1 1/2". Took the suspension apart and re-greased everything, Re-did the alignment. Still couldnt launch the car higher than 1100rpm.
Overall the car picked up almost a full 2 tenths and 2mph over its previous best. 60' stayed the same at it's best 1.68. This is the best air and track the car was ever run in, was great air, I think right at sea level, best previous was 1200ft. I think I picked up more than most of the guys?
On an interesting note, the car picks up an even amount .1 in the 60' equalled exactly .1 in the quarter.
