Tricks of the Trade... #1110076
11/09/11 09:54 AM
11/09/11 09:54 AM
NY
F1Scamp Offline OP
F1Scamp  Offline OP
NY
Whats some of the tricks for getting the last little bit of mph, e.t. out of your car. I am going to be shooting for the smallblock record in F.A.S.T. this weekend at MIR. I am going to need every little trick I can find. You always hear people say they have there car " Set on Kill", what the heck does that mean? I run the car out everytime. Should I be thinking of thinner oil, etc. etc. Does changing where the car goes into staging beams make a difference on et.? Any help or ideas would be appreciated.
Car is 71 Duster, 402cu in stroker smallblock, factory heads, intake, exhaust manifold, thermoquad. All worked.
Work In Progress- 71' Duster F.A.S.T.- 10.36@130 Smallblock Record Holder.
Re: Tricks of the Trade... [Re: F1Scamp] #1110077
11/09/11 10:15 AM
11/09/11 10:15 AM
Texas
dannysbee Offline
dannysbee  Offline
Texas
Stage as shallow as possible. Put as much air as possible in the front tires. Synthetic lube in everything. The stock guys run less oil in the engine. I might skip that mod. Loosen up the accessory belt so it will slip at higher rpm.
Getting old just means you were smarter than some and luckier than others.
Re: Tricks of the Trade... [Re: dannysbee] #1110078
11/09/11 10:19 AM
11/09/11 10:19 AM
gregsdart Offline
gregsdart  Offline
904 trans if legal. 8 1/4 rear?
Re: Tricks of the Trade... [Re: gregsdart] #1110079
11/09/11 11:09 AM
11/09/11 11:09 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Switch on alt to turn off during run.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Tricks of the Trade... [Re: 1967dartgt] #1110080
11/09/11 01:17 PM
11/09/11 01:17 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
0w20 synthetic oil, bring a big fan to cool the engine between rounds, synthetic light weight gear oil as thin as you dare, pack ice bags with shaved ice all around the intake and carb between rounds, drop the t-bars till it is almost sitting on the bump stops (weight transfer in the 60ft and aero dynamics at the fast end), have the alighnment double checked, you want the wheels to end up with zero toe while rolling down the road, I like to spread the front of the wheels while setting the alighnment and set the toe to zero, thay seem to roll a lot easier when setting them this way, if you run the carb a tad lean to keep the plugs clean then richen it up to run it's fastest. Remove floor mats, glove box, contents, jack, spare tire, trunk mat all excess fuel (don't fill it for ballast, sloshing ballest does almost no good, if you need ballast bolt it in the trunk as close to the bumper and high as possible, if you can bolt it to the roof of the rea edge of the trunk even better), set rear drums for no drag, WD-40 on all the front end rubber bushings to loosen them up a little, make sure you leaf spring clamps are good and tight...
If I think of any more I will post em up
Re: Tricks of the Trade... [Re: HotRodDave] #1110081
11/09/11 01:42 PM
11/09/11 01:42 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Several years ago I was going to build a 71-72 TQ 340 based 904 backed Duster for F.A.S.T. but about that time they asked me to be their Tech guy so I got side-tracked and sold the car. It was a 72 Twister /6 car in really nice shape I sold to B body Bob. I was planning a 4.1 x 4.1" 433 motor using light 2.05" thin stem intake valves and my own cam specs.
Take full advantage of the Duster's long rear overhang, just 10 more static pounds added behind the bumper (like adding the 13 pound 1973 reinforcing plate) can have the same dynamic effect as putting a 40 pound battery 1 foot behind the rear axle centerline. Duster's and Chevy II wagons are the best "natural hook" cars I've ever played with.
Have the allignment shop physically jack the front end of the car approx 1-1/2" inches BEFORE setting the allignment....this will simulate the car under acceleration and decreases the rolling resistance down the track. Dynamat in floor of the spare tire well adds a few strategic pounds in just the right place as well.
Amsoil gear lube is typically worth at least ~.03 on most cars I've ever back to back tested...I like to get some heat in the rear axle by idling the drivetrain on stands in the pits for a few minutes.
If you're serious about it dyno-tune the car on a chassis dyno before the race documenting every 'cause and effect' jetting and timing change.
WIZE
In Car:
Re: Tricks of the Trade... [Re: HotRodDave] #1110082
11/09/11 01:46 PM
11/09/11 01:46 PM
South Lyon, Michigan
6bblRoadrunner Offline
Re: Tricks of the Trade... [Re: Streetwize] #1110083
11/09/11 01:49 PM
11/09/11 01:49 PM
Renton Washington
Triple Threat Offline
Renton Washington
Get all the oils hot and thin, and the water and intake as cold as possible.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Tricks of the Trade... [Re: 6bblRoadrunner] #1110084
11/09/11 01:56 PM
11/09/11 01:56 PM
Guitar Jones Offline
Check this out...
http://www.dvorakmachine.com/tech_LastMinuteHeroics.shtml
"Add another 1/2 quart of oil Dan". LMAO
Re: Tricks of the Trade... [Re: Guitar Jones] #1110085
11/09/11 08:20 PM
11/09/11 08:20 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
An old buddy of mine, who came up through Stockers into the early Funny cars, used to dip his wheel bearings in oil as opposed to packing them with grease. He'd set everything just tight enough to go straight, suspension bushings loose but still locating their assigned parts, that kind of thing. His big thing was to minimize any rolling or moving resistance in the car. That Dvorak article is excellent, BTW.
Re: Tricks of the Trade... [Re: 1967dartgt] #1110086
11/09/11 09:01 PM
11/09/11 09:01 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I use to do this...made 0 change if the battery is up
to full charge... use as much air pressure as you can
in ALL of the tires... thinnest oil as possible plus
1 QT low... crank scraper if allowed
Re: Tricks of the Trade... [Re: MR_P_BODY] #1110087
11/09/11 09:08 PM
11/09/11 09:08 PM
cincinnati ohio
mcat4321 Online content
mcat4321  Online Content
cincinnati ohio
take a hammer and dent the floor pan under the gas pedal, so it goes down farther
Re: Tricks of the Trade... [Re: mcat4321] #1110088
11/09/11 09:47 PM
11/09/11 09:47 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
small wheels up front, big one's on the back ... so it's always going downhill!
Re: Tricks of the Trade... [Re: Stanton] #1110089
11/10/11 09:32 AM
11/10/11 09:32 AM
NY
F1Scamp Offline OP
F1Scamp  Offline OP
NY
Thanks guys for the suggestions. It has a 904 trans and a spool equipped rear. I wish I could put some real tires on it and it still be legal. lol. I am going to pick up some 0 weight oil, and I have a few ideas on how to cool the car down between rounds. I need to get this carb straightened out still also, a/f last time out was around 10-11:1.
I didn't realize that nitrogen is that much lighter and can make that much difference in the weight of the tires. I have a nitrogen tank and regulator at work.... 6-8 lbs of rotating weight would be nice to get off.
Keep them coming!
Re: Tricks of the Trade... [Re: F1Scamp] #1110090
11/10/11 09:33 AM
11/10/11 09:33 AM
NY
F1Scamp Offline OP
F1Scamp  Offline OP
NY
Also I picked up a 16v race battery, figure it is worth a try? Anybody gain anything switching from 12v to 16v?
Re: Tricks of the Trade... [Re: F1Scamp] #1110091
11/10/11 11:38 AM
11/10/11 11:38 AM
Texas
dannysbee Offline
dannysbee  Offline
Texas
Keep adding weight to the rear of the car and launch the car more aggressively. When the car slows down go to the weigh of you fastest pass. I think the 60's will improve enough to over come the cost of the extra weight.
Re: Tricks of the Trade... [Re: dannysbee] #1110092
11/10/11 11:42 AM
11/10/11 11:42 AM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
I only saw the request for more mph, didn't even look at e.t.
Thats the bracket guy in me,, et means nothing but a number on your windshield.
Re: Tricks of the Trade... [Re: RemCharger] #1110093
11/10/11 12:58 PM
11/10/11 12:58 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
Just turn the starting line rev limiter up
Re: Tricks of the Trade... [Re: F1Scamp] #1110094
11/10/11 07:49 PM
11/10/11 07:49 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Brian
I can get you two tenths. No tools needed. FAST legal 100%. If you are interested, give me a call......
MB
Re: Tricks of the Trade... [Re: HPMike] #1110095
11/10/11 07:56 PM
11/10/11 07:56 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
Mike, I think he is already running the FireCore 250 8mm wires.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
