Re: Tricks of the Trade...
[Re: scatpacktom]
#1110097
11/10/11 08:30 PM
11/10/11 08:30 PM
Posts: 6,446 NJ-USA
HPMike
NJ-USA
Bring some for me too Mike! GLUG GLUG GLUG
You going?? I'm makin the trip..
MB
[Re: F1Scamp]
#1110102
11/10/11 10:39 PM
11/10/11 10:39 PM
Posts: 6,257 acworth / N. georgia - south e...
cheapstreetdustr
have you tried putting an ignition retard module in it? retard the ignition timing 2*-3* after it shifts into high gear..
cheapst
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
[Re: F1Scamp]
#1110104
11/10/11 11:22 PM
11/10/11 11:22 PM
Posts: 6,446 NJ-USA
HPMike
NJ-USA
Brian
I can get you two tenths. No tools needed. FAST legal 100%. If you are interested, give me a call......
MB
You messing with me Mike? I only have your shop number..
Nope, I'm serious
Leave the carb tune alone and call me tomorrow if you want..
MB
[Re: Rapid340]
#1110106
11/11/11 10:09 AM
11/11/11 10:09 AM
Posts: 3,103 Phila Pa
scatpacktom
Phila Pa
Hope both you guys do well. Have fun and be safe.
Thanks Jeff
[Re: scatpacktom]
#1110107
11/22/11 09:21 PM
11/22/11 09:21 PM
Posts: 5,160 Texas
dannysbee
Texas
Well did anything here help the cause?
Getting old just means you were smarter than some and luckier than others.
[Re: dannysbee]
#1110108
11/22/11 09:57 PM
11/22/11 09:57 PM
Posts: 419 NY
F1Scamp
NY
The 0w oil didn't do anything but freak me out going down the track. The 16v battery was worth something. I am assuming the alternator not working had something to do with it, though it seems to even idle better. My homemade vacuum pump was worth something. Tuning the carb was worth something. Staging shallow made a huge difference. Making the rear brakes stop dragging I am sure helped. Lowered the front and rear of the car over 1 1/2". Took the suspension apart and re-greased everything, Re-did the alignment. Still couldnt launch the car higher than 1100rpm. Overall the car picked up almost a full 2 tenths and 2mph over its previous best. 60' stayed the same at it's best 1.68. This is the best air and track the car was ever run in, was great air, I think right at sea level, best previous was 1200ft. I think I picked up more than most of the guys? On an interesting note, the car picks up an even amount .1 in the 60' equalled exactly .1 in the quarter.
Work In Progress- 71' Duster F.A.S.T.- 10.36@130 Smallblock Record Holder.
