96 Dodge Caravan running rough. Any suggestions?
#1109477
11/08/11 05:18 PM
11/08/11 05:18 PM
Posts: 1,273 Minneapolis, MN
moparguy
Minneapolis, MN
I'm trying to help out my Uncle with his 96 Dodge Caravan. 3.0 engine. it runs extremely rough, and gets rougher in reverse it seems. I've checked the injectors, coil packs, plugs, wires, etc. To no end. I've also checked out the wiring and replaced the PCM with a known good one.
Is it possible a Crankshaft position sensor could make this run really rough? It will idle by itself without having to get into the throttle, which is different from other vehicles i've had where the CPS went out.
Does anybody have any suggestions on this one?
Thanks everyone!
Re: 96 Dodge Caravan running rough. Any suggestions?
[Re: moparguy]
#1109478
11/08/11 05:30 PM
11/08/11 05:30 PM
Posts: 21,088 Niles , Ohio
therocks
Niles , Ohio
Dosent that have a dist?Does it have any codes?Thats the first thing to check.Rocky
Chrysler Firepower
[Re: moparguy]
#1109480
11/08/11 08:05 PM
11/08/11 08:05 PM
Posts: 905 SD
zrxkawboy
SD
Don't overlook mechanical problems, such as intake leak, head gasket, etc.
It's Swifty! Swifty, you toad sucker!
[Re: moparguy]
#1109481
11/08/11 08:30 PM
11/08/11 08:30 PM
Posts: 21,554 N.E. OHIO, USA
A12
N.E. OHIO, USA
Clean the throttle body!! Then check for vacuum leaks. or.....the good and bad news http://consumerguideauto.howstuffworks.com/1996-to-2000-dodge-caravan-6.htmRough idle: Rough running in 3.3-liter and 3.8-liter V6 might be due to broken pedestals in the cylinder heads. (1996) Rough idle: Vehicles equipped with a 3.3-liter or 3.8-liter V6 may lose power and/or buck and miss. Problem can be fixed by disconnecting the knock sensor. (1996-97)MikeR
[Re: Magnumguy]
#1109483
11/09/11 12:19 AM
11/09/11 12:19 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
That has to be a 3.3 as they did not make the 3.0 in that year Caravn with a coil pack. The 3.0 is an overhead cam eng and the 3.3 is a pushrod eng. As was said we had some trouble with the pedestals breaking on the rear cyl head from lack of oil becaus the cam bearing would turn in some. Did you check comp ? Ron
[Re: 383man]
#1109484
11/09/11 12:33 AM
11/09/11 12:33 AM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
I agree with the others, the 3.0 had dist. ign not packs. Either it is a 3.3, 3.8, or it has a dist.
I have seen them (3.3 3.8)break the pedastals but also blow some head gaskets and run puny. Usually when a coil pack goes bad it sends miss-fire codes for 2 individual cylinders, one cylinder means bad plug or wire, multi-cyl is usually something that affects all of them. I have seen a lot of people put Bosche spark plugs in them and cause mis fires, even with new plugs. I would pull the plugs, look for anything on them that shouldn't be there and run a compression test.
