trans guys, aode/4r70w endplay?? #1108621
11/07/11 11:54 AM
11/07/11 11:54 AM
Alton, IL
Dakota_Don Offline OP
Alton, IL
Hello, on this unit..(my first aode/4r70w) should the input shaft move in and out like a 4l60.. I did the check with the .700 bar gauge.. I have 1.636 on the intermed clutch.. and on the hub 1.513.. according to manual its the yellow thrust washer.. but i cannot pull the input shaft in and out.. nor does the manual or the internet show anything like that..
Thanks Don
618 216 3700
Re: trans guys, aode/4r70w endplay?? [Re: Dakota_Don] #1108622
11/07/11 08:53 PM
11/07/11 08:53 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
yes with the trans assembled you should have some end play on the input shaft.And i hop you meant .163 and not 1.63
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
