spray bar valve covers #1108037
11/06/11 11:59 AM
11/06/11 11:59 AM
nc
E
earthmover Offline OP
E
nc
is indy the only 1 that makes these??????
Re: spray bar valve covers [Re: earthmover] #1108038
11/06/11 01:45 PM
11/06/11 01:45 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
make your own. its not rocket science.
Re: spray bar valve covers [Re: rebel] #1108039
11/06/11 02:24 PM
11/06/11 02:24 PM
nc
E
E
nc
im sure its not ..this will be for a buddy and he has passed on a set that was made and didnt like them..just didnt know if anybody else made the ..thanks mike
Re: spray bar valve covers [Re: earthmover] #1108040
11/06/11 02:35 PM
11/06/11 02:35 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
does indy have a valve cover with this incorporated, or do they just install their kit into their valve cover?
Re: spray bar valve covers [Re: joshking440] #1108041
11/06/11 02:50 PM
11/06/11 02:50 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Yep
Pretty much a cheap kit that they sell for hundreds of dollars. Its like $250 for the oiling kit, maybe $60 worth of parts.
I had a set for sale in the parts section, I couldnt hardly give away. Its one of those things where you cant find them when you need them, but a very small market for guys that use/need these.
Here is a few sets. Both have the same parts etc. Not sure who's kit etc, one in a cheap set of factory covers, and the other in a set of aluminum older B1 covers.
Sometimes pics are worth looking at! So hope this helps.
Bulk head end (indside)
Outside Bulk head
End is pretty much just pinched off and brazed etc. Both lines are made of stainless.
Older set
last one
Re: spray bar valve covers [Re: Bob_Coomer] #1108042
11/06/11 02:52 PM
11/06/11 02:52 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Some other thoughts..
Most of the Indy kits I have seen use a T that runs through the cover in the middle then splits to both sides. Just seems like those would be more expensive to make, and require more work, than these.
I made my own out of 3/16 brake line Inverted flared fittings, so its not difficult as mentioned.
