Re: Who is real good setting up six pack carbs ?
[Re: meepmeep70]
#1107272
11/04/11 09:22 PM
11/04/11 09:22 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
not the answer you want but,the answer should be you,trust me when i say you need to be the one to work on,cuz stuff happens and you'll need to know,one of those learning curves i'm thankful to have been given guidence to
a whole lotta truth right there. and there's plenty of help to be found on this site!
[Re: mikemee1331]
#1107273
11/04/11 09:25 PM
11/04/11 09:25 PM
Posts: 3,426 weymouth,mass.
meepmeep70
weymouth,mass.
exactly!!! folks on this site are more then willing to help,IF you give the effort,i'm happy as a clam with my 6pak,learned alot right here ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: meepmeep70]
#1107276
11/04/11 10:06 PM
11/04/11 10:06 PM
Posts: 3,916 usa
lewtot184
usa
x3! do it yourself.
[Re: Mr.Yuck]
#1107282
11/05/11 06:13 PM
11/05/11 06:13 PM
mikemee1331
bethlehem pa
It's not hard ..I did mine. Never touched a set before. I'd stick w/ the stock jets..maybe go up a size. If you are pulling 15 at idle the factory 6.5 pv wil be fine. make sure the flaots are set right. then turn the idle screws in all the way in. Next turn them out 1.25 turns. start the car and run the idel up to 2400. UNHOOk the vac advance and set the timing in full at 38*. Turn the idle back down to 900, adjust the screws for best vaccum and go for a blast.
x2, you also don't mention how old or abused the carbs are. instead of doing what RR suggested, it might be time to just rebuild them. the kits are about $20 each (you need 3)and contain everything you need except a lower power valve which you will probably need once you pull a vacuum check. i think the kits come with a 6.5.
[Re: mikemee1331]
#1107283
11/05/11 06:29 PM
11/05/11 06:29 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
my kit was brand new. if you have an old set...by all means buy a rebuild kit. It's not hard. and when the outboards open it's like no 4bbl!
[Re: GLR]
#1107286
11/06/11 05:31 AM
11/06/11 05:31 AM
Posts: 908 North Chicagoland
newbee69
North Chicagoland
I was wondering if I should get the 340 carbs or the 440 carbs ...or...the demons????
I thought I read somewhere that the 340 carbs would perform better than the 440's on a 383....Forgot where I read it or why....but I pretty sure Ive heard this before. ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: GLR]
#1107288
11/06/11 02:18 PM
11/06/11 02:18 PM
meepmeep70
weymouth,mass.
Yes, I think I either read that in a magazine or on here some time ago. Anyone know if 340 carbs would work better than the 440 carbs?
yes,that is what i was told,bought them and very happy,bought from summit,sometimes back ordered so order soon,if you decide ![](/ubbthreads/images/graemlins/luck.gif)
