64 Dodge dashpad removal
#1106899
11/04/11 12:54 AM
11/04/11 12:54 AM
Posts: 2,048 N.E.Ohio
Polarabill
N.E.Ohio
Removing this dashpad is new to me.I could use a little help on how to do it.Is it glued to the top of the dash or do I need to start tearing out glove box,radio and gauge cluster.I looked up under the dash and didn't see any thing that looked like it might be holding the pad on. There was a trim strip on the front/bottom of the pad that is missing.Thanks for any hints,tricks and help.
This would be so much easier if I knew what I was doing...
Re: 64 Dodge dashpad removal
[Re: Polarabill]
#1106900
11/04/11 01:33 AM
11/04/11 01:33 AM
RapidRobert
I think there's 5 or 6 studs integral with the dash pad that extend thru the metal dashboard and there's those thin tinnerman? type flimsy nuts on the studs. long 1/4 or 3/8 extension and a 3/8" socket and a penlight and yes they're hard to get to and get a straight shot at
[Re: In_The_Pink]
#1106903
11/04/11 09:49 AM
11/04/11 09:49 AM
Polarabill
N.E.Ohio
The car is a Polara and just has a partial pad-maybe 5-6" wide.Thanks for the pics abd info.I knew you guys could and would help.
[Re: Polarabill]
#1106904
11/04/11 08:27 PM
11/04/11 08:27 PM
Posts: 456 Santa Barbara, CA
HitIt
Santa Barbara, CA
My 64 Dodge dash pad is held on with 4-5 tension clips... little X shaped spring clips that snap into the metal dash.
I'll look for a picture but I'm pretty sure as I remember one of those metal spring clips scratched my new dash paint !
very clever dinner. appetizing food fit neatly into interesting round pie.
[Re: HitIt]
#1106905
11/04/11 08:32 PM
11/04/11 08:32 PM
HitIt
Santa Barbara, CA
couldn't find a pic of the bottom of my dashpad, but here is the style of my dash pad... should be the same as your Polara.
[Re: HitIt]
#1106906
11/04/11 09:18 PM
11/04/11 09:18 PM
Polarabill
N.E.Ohio
Thats what it looks like.As soon as I get a chance I'll get it out.Thanks again.
[Re: Polarabill]
#1106907
11/05/11 01:08 PM
11/05/11 01:08 PM
HitIt
Santa Barbara, CA
Glad to help! So the spring clips are along the edge of the pad closest to the windshileld. If you contort well enough, you should be able to get at them with some needle nose pliers without removing anything else. Good luck.
