Anyone using the Lunati 60301 cam in a 30 over 383? #1106803
11/03/11 11:00 PM
11/03/11 11:00 PM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
I was just wondering if anyone is running a Lunati 60301 VooDoo cam in a 30 over 383? If so....how do you like it?
Re: Anyone using the Lunati 60301 cam in a 30 over 383? [Re: GLR] #1106804
11/04/11 04:58 PM
11/04/11 04:58 PM
st.cloud fl
d-150 Offline
Smarter than a 5th grader?
d-150  Offline
st.cloud fl
use 60303
Re: Anyone using the Lunati 60301 cam in a 30 over 383? [Re: GLR] #1106805
11/04/11 05:38 PM
11/04/11 05:38 PM
NL
Frederick Offline
Frederick  Offline
NL
Using the 60302 in my 383.
Vacuum is 15"Hg so no worries with power brakes and it pulls good from 1500rpm.
Idle is very smooth once I got the timing and carb adjusted.
Like it a lot.
383B, 9.8:1, Lunati 60302(220/226@0.050 262/268Dur, 0.475"/0.494", Stealth heads, Performer manifold, QF SS-750-AN carb, 3.31Diff, A833 4-speed manual.
Re: Anyone using the Lunati 60301 cam in a 30 over 383? [Re: GLR] #1106806
11/04/11 05:45 PM
11/04/11 05:45 PM
Oklahoma
TinCuda Offline
TinCuda  Offline
Oklahoma
Lunati makes a very nice cam. You will have no problems with it.
I am using a Lunati 60303 cam in my 440 build.
As a bonus, you can put their killer stickers on everything...LOL
(O O {]{]{]||[}[}[} O O) 1971 Plymouth 'Cuda 440-6 {||O||} 2000 Yamaha V-Max (O O [========= SRT] O O) 2011 Dodge Challenger SRT 392 . Making as big as a carbon footprint as I can!!!
Re: Anyone using the Lunati 60301 cam in a 30 over 383? [Re: Frederick] #1106807
11/04/11 05:56 PM
11/04/11 05:56 PM
Conway, SC
T2R9 Offline
T2R9  Offline
Conway, SC
Like it a lot.
Same here. using the 60302 in my 440 great idle, great power. I think you will find the 60301 mild.
Re: Anyone using the Lunati 60301 cam in a 30 over 383? [Re: GLR] #1106808
11/04/11 06:16 PM
11/04/11 06:16 PM
Oklahoma
TinCuda Offline
TinCuda  Offline
Oklahoma
I just looked up the specs on a 60301. If you are using it in a mostly stock engine, it will be fine.
•Advertised Duration (Int/Exh): 256/262
•Duration @ .050 (Int/Exh): 213/220
•Gross Valve Lift (Int/Exh): .454/.475
•LSA/ICL: 112/108
•Valve Lash (Int/Exh): Hyd/Hyd
•RPM Range: 1000-5500
Re: Anyone using the Lunati 60301 cam in a 30 over 383? [Re: T2R9] #1106809
11/04/11 06:23 PM
11/04/11 06:23 PM
The Dalles, OR.
Dusted_Ya Offline
Dusted_Ya  Offline
The Dalles, OR.
I'm using the 60301 in one of my 440 Powerwagons. Great cam! Pulls from the basement! Excellent for a street driven car also as there's no lag at low RPM's Nice thing about this cam is you can use stock torque converter and valve train.
Re: Anyone using the Lunati 60301 cam in a 30 over 383? [Re: Dusted_Ya] #1106810
11/04/11 08:26 PM
11/04/11 08:26 PM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
Thank you to everyone that posted to my post!
I am building the 383 engine for street use and trying to achieve the best fuel economy for going on long trips but still being able to have good performance. This cam is supposed to give 19 inches of vacuum at idle and have excellent throttle response. I am going to be installing a six pack set up on it with a 5-speed standard transmission with 3:23-to-3:91 sure grip (depending on the transmission gear ratio ) with a 27-28" tall rear tires.
