Re: motor plate or solid mount
[Re: Dragula]
#1106718
11/04/11 08:53 AM
11/04/11 08:53 AM
Posts: 13,385 Marion, South Carolina [><]
an8sec70cuda
I say put a plate in it now and be done w/ it. Much easier to R&R the engine and real nice to mount stuff on. Don't use gaskets for the water pump, just use silicone.
[Re: bonefish]
#1106720
11/04/11 09:58 AM
11/04/11 09:58 AM
an8sec70cuda
He'll have to get a low mount kit. I think he was asking about going to an electric water pump a week or 2 ago, so belt/pulley alignment won't be an issue.
[Re: an8sec70cuda]
#1106721
11/04/11 10:16 AM
11/04/11 10:16 AM
Posts: 75 southwest pa
bodyworks racing
southwest pa
i did put the elecric pump and low mount alt on already im thinking maybe just bite the bullit and do the plate ok next question who"s plate was not impresed by competion engeneering or summit and jegs.mancini however has one made from t-6 3/8 thick cut on a water jet anybody run one? thanks for the replys 383 man are you going to hagerstown?
68 ROADRUNNER 440 HORSE POWER IS HOW FAST YOU HIT THE WALL TORQUE IS HOW FAR YOU TAKE THE WALL WITH YOU
[Re: bodyworks racing]
#1106723
11/04/11 10:22 AM
11/04/11 10:22 AM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
did you use the mopar alt or did you have to get a special alt.?
#1106724
11/04/11 10:34 AM
11/04/11 10:34 AM
an8sec70cuda
I just use the Comp Engineering plates on mine. No need for the thicker plates in my opinion. I like the fact that the CE plates are one big sheet w/ no holes in it so you can cut it to fit how you want it and can mount stuff all over it.
[Re: an8sec70cuda]
#1106725
11/04/11 10:41 AM
11/04/11 10:41 AM
Posts: 642 New Jersey
Craig
New Jersey
Supposedly, mounts cost power compared to a plate due to cylinder wall flex and reduced ring seal. Not sure what power levels this would begin at though.
67 Dart, 426 Hemi, 9.23/145mph, 3400lbs, footbraked, owned since 1982
[Re: nhramark]
#1106727
11/04/11 12:33 PM
11/04/11 12:33 PM
Posts: 3,104 Wheels up, MO
nhramark
Wheels up, MO
Well that pic was too big, I'll fix it later. But here is a small block plate we made.
[image]http://s1126.photobucket.com/user/nhramark1/library/Racing[/image]
9.100 @ 150 mph
5.780 @ 120 mph
[Re: nhramark]
#1106728
11/04/11 12:36 PM
11/04/11 12:36 PM
nhramark
Wheels up, MO
And a Gen3 Hemi 3/8" plate we made for another member here..... you get the idea.
9.100 @ 150 mph
5.780 @ 120 mph
