Re: Hemi 99 Flow numbers
[Re: moderncylinder]
#1105902
11/02/11 04:19 PM
11/02/11 04:19 PM
Posts: 12,418 Taxes & Virus's R-US, NY
Dragula
580cfm was a good number awhile ago,, now its probably 600-620
2.560 was the std valve size back awhile ago aswell,, but i know things are bigger now
Wow!
One of those would look really cool in my Cuda...
[Re: Dragula]
#1105903
11/02/11 07:05 PM
11/02/11 07:05 PM
Posts: 19,384 Las Vegas
Al_Alguire
Las Vegas
Well they do not use the 99 Hemi any longer. They have a new symetrical port head these days. FWIW my 99 uses a 2.55x6.830 valve. As for flow 570-90 seems typical.
[Re: Al_Alguire]
#1105904
11/02/11 11:42 PM
11/02/11 11:42 PM
Posts: 1,841 NW Indiana
fbs63
NW Indiana
My heads are Nickens circa 2002-03 and go 590 @ 1.060 with a 2.540 intake. They have a D-shaped intake port.
[Re: WO23Coronet]
#1105906
11/03/11 02:19 PM
11/03/11 02:19 PM
Posts: 2,840 Flint, Michigan
B1Fish540
Flint, Michigan
I just read something about that over pon Allpar, but they didn't have any pictures. Does it still have the layout like the 99 HEMI or is it different? Does anyone have any pics? Per Allpar it sounds like they will be using both heads for the 2012 season.
Yes! PIX! PIX!
[Re: quickd100]
#1105910
11/05/11 12:14 AM
11/05/11 12:14 AM
Posts: 3,505 DFW
mr_340
DFW
Sort of off topic, but what bolt pattern is on the back of the blocks? Is it the GM pattern or Mopar?
Floyd Lippencott IV
[Re: cudacustoms1]
#1105912
11/05/11 09:33 AM
11/05/11 09:33 AM
Posts: 1,107 Quebec, Canada
Diablo
Quebec, Canada
How many different versions of these heads have they made and what are the differances. I had read some thing about rocker stands (1,2,or 3) bolt. Is the head bolt pattern the same? How about bore spacing? Just trying to learn more about these motors. Thanks for any info.
From what I know there were the 5.000 BS heads made and the 4.900. 5.000 for promod and the 4.900 which are still used in pro stock.
Development on the 5 inch stuff has stopped because all the promod cars are now using the 5.3 bs stuff.
As for the newest heads they have a 4 bolt hold down for the rocker system.
[Re: Al_Alguire]
#1105915
11/06/11 04:14 PM
11/06/11 04:14 PM
Diablo
Quebec, Canada
If anyone wants I can take pics of my stuff.
Were we gonna get some pretty pictures?
Also did anyone know if those flow numbers were max numbers or down at .900-1.000 lift?>
[Re: cudacustoms1]
#1105917
11/07/11 08:32 AM
11/07/11 08:32 AM
Posts: 6,150 Melbourne , Australia
LA360
I think there was was 7 and 9 cam bearing options, the later having the extra cam bearing journals. Could someone verify this?
I also find it interesting that they have gone away from the mirrored port layout and to the symmetrical port. Was the mirrored layout a fad?
Alan Jones
