uncovering inspection marks #1105853
11/02/11 11:58 AM
11/02/11 11:58 AM
Iowa
burdar Offline OP
Owen's Dad
burdar  Offline OP
Owen's Dad
Iowa
I may be over thinking this but I'll ask it anyway.
The center section of my 8 3/4 rear is covered in caked on filth. I'm hoping that the inspection marks have been preserved under all that stuff. How should I go about cleaning off all the grime without damaging any marks that may still be there? I've never had much luck with "Gunk" degreaser and I don't want to just start wire brushing it.
Also, I know a lot of people use muratic acid to clean rusted parts. Does anyone have any tips or tricks to using it effectivly? What ratio works best? What if you don't want to dip the parts? Can you just brush it on full strength? Thanks
Re: uncovering inspection marks [Re: burdar] #1105854
11/02/11 12:06 PM
11/02/11 12:06 PM
Ridgeland Wi
mopars_1 Offline
mopars_1  Offline
Ridgeland Wi
I just steam cleaned my axle and all of the marks showed up just fine
1971 Plymouth Duster 340 auto
1937 Plymouth PT50
1969 Dodge Dart Swinger 340 4 speed
2013 Ram laramie 2500 hemi
2008 Harley FLSTSB springer
Re: uncovering inspection marks [Re: mopars_1] #1105855
11/02/11 12:14 PM
11/02/11 12:14 PM
Iowa
burdar Offline OP
Owen's Dad
burdar  Offline OP
Owen's Dad
Iowa
My rear axle housing was one giant mass of crusty rust. I had it sand blasted a long time ago. I might have gotten some marks off of it if I'd known about products like EvapoRust at that time. Now those are gone forever. I thought I'd ask about the center section before I did something to destroy those too.
Re: uncovering inspection marks [Re: mopars_1] #1105856
11/02/11 12:26 PM
11/02/11 12:26 PM
NO RUST IN AZ!!!
azmopar Offline
azmopar  Offline
NO RUST IN AZ!!!
what about an engine still in the car?
70 Challenger Convertible 340 six pak CLONE?
70 Duster real FM3 car
65 Dart Charger FOR SALE
#NONIKESEVER
A Real man aint afraid to drive PINK!!!!
67 Plymouth Valiant PILOT CAR 273 Commando 4 spd
Re: uncovering inspection marks [Re: azmopar] #1105857
11/02/11 12:45 PM
11/02/11 12:45 PM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
I used dawn dishsoap (or tide) water, brush, and fine/med steel wool to get all mine back.
Re: uncovering inspection marks [Re: NV69B7RR] #1105858
11/02/11 02:11 PM
11/02/11 02:11 PM
Oakville, Ontario, Canada
CDN72SE Offline
CDN72SE  Offline
I used Castrol Super Clean in my situation as it was really tough to get off. At the time I didn't realize or know about the markings. The shiny part was after I took a 3M wheel to it.
Re: uncovering inspection marks [Re: CDN72SE] #1105859
11/02/11 09:27 PM
11/02/11 09:27 PM
Iowa
burdar Offline OP
Owen's Dad
burdar  Offline OP
Owen's Dad
Iowa
Well, it's not looking good. Not much of anything is showing up. It looks like there is a yellow line by the fill plug.(did they use paint or a grease pencil?)
There's an orange dot about the size of a quarter with a run on the top and remnants of a stencil on the side. I can't make it out though.
I assume the muratic acid will just eat everything away right? Is dipping the entire housing in EvapoRust the only option to remove some rust without destroying the marks? I soaked the original coil in EvapoRust and all the marks reapeared.
Thanks for the suggestions so far.
Re: uncovering inspection marks [Re: burdar] #1105860
11/03/11 12:23 AM
11/03/11 12:23 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
One trick that helped make markings readable on my axle was spraying it down with WD40
Re: uncovering inspection marks [Re: 1_WILD_RT] #1105861
11/03/11 12:31 AM
11/03/11 12:31 AM
Iowa
burdar Offline OP
Owen's Dad
burdar  Offline OP
Owen's Dad
Iowa
I can try that thanks. It's also possible that this center section didn't have many markings. I just don't want to destroy any of them by cleaning the housing to aggressively.
Re: uncovering inspection marks [Re: burdar] #1105862
11/03/11 02:28 AM
11/03/11 02:28 AM
Washington
19cuda73 Offline
19cuda73  Offline
Washington
Here is a bottom view from my unit
1966 Charger 383 4 speed (Black with Red interior)
1973 Cuda 340 4 speed (Lemontwist)
1972 Corvette
Re: uncovering inspection marks [Re: 19cuda73] #1105863
11/03/11 02:30 AM
11/03/11 02:30 AM
Washington
19cuda73 Offline
19cuda73  Offline
Washington
side view clean with a stiff bristle brush and simple green.
1972 Corvette
Re: uncovering inspection marks [Re: 19cuda73] #1105864
11/03/11 02:35 AM
11/03/11 02:35 AM
Washington
19cuda73 Offline
19cuda73  Offline
Washington
view from the rear. I believe J signifies a 73 and the x means it was serviced with fuild.
1972 Corvette
Re: uncovering inspection marks [Re: 19cuda73] #1105865
11/03/11 09:44 AM
11/03/11 09:44 AM
Iowa
burdar Offline OP
Owen's Dad
burdar  Offline OP
Owen's Dad
Iowa
Yours has a yellow grease pencil mark by the fill plug just like mine. Mine also has some white stenciling on the side. I think I'm going to soak as much of it as I can in EvapoRust to see if anything else shows up. Right now I'm not seeing anything on the very bottom. Maybe 2.76 gears didn't get any markings there.
Thanks for the pictures everybody.
Re: uncovering inspection marks [Re: burdar] #1105866
11/03/11 12:09 PM
11/03/11 12:09 PM
Washington
19cuda73 Offline
19cuda73  Offline
Washington
I believe your correct, Ive heard the paint codes on the bottom did represent gear ratio but never did find out all the details. Im also unsure of the OY1 marking on the side in white Maybe we'll hear more from other members.
1972 Corvette
Re: uncovering inspection marks [Re: 19cuda73] #1105867
11/03/11 02:33 PM
11/03/11 02:33 PM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
The paint markings on the bottom did correspond with the gear ratio, also and additional orange splotch designated a sure grip. I have a chart that tells what splotches were for what ratio.
On my 8 3/4 the # (A914) on the pumpkin coinsided with the same # on the drivers side axle tube, which was most likely the date the rear end was assembled (in my case).
Re: uncovering inspection marks [Re: NV69B7RR] #1105868
11/03/11 02:37 PM
11/03/11 02:37 PM
CDN72SE Offline
CDN72SE  Offline
This is what I had posted in another link.
Rear end paint markings
Re: uncovering inspection marks [Re: CDN72SE] #1105869
11/04/11 09:06 PM
11/04/11 09:06 PM
Iowa
burdar Offline OP
Owen's Dad
burdar  Offline OP
Owen's Dad
Iowa
Thanks for posting that list Alan. I've seen it before but didn't know if it was accurate for the later years. I just uncovered two yellow marks on the bottom so it looks like that chart still applies in 73.
After getting most of the grease off the carrier not much was visable. I had some old almost used up EvapoRust so I thought I see if it would do anything. I'm amazed that the marks were still there under the rust. Here's what I found.
orange mark on top...I can't tell if the flat pad is painted black or if it's just dark rust.
two yellow marks on the bottom (2.76 gear)
This is all I could see after cleaning the grease off the side.
After soaking in EvapoRust.(it looks like 10Y with a 7 above it)
Re: uncovering inspection marks [Re: burdar] #2278952
03/30/17 03:52 PM
03/30/17 03:52 PM
CDN72SE Offline
CDN72SE  Offline
Just throwing this back up there.
