95 Breeze 2.4 rear main seal
#1105641
11/01/11 11:02 PM
11/01/11 11:02 PM
Posts: 28,071 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
How much of a PITA is it to change the rear main seal on one of these? A friend of mine noticed his was leaking. It apparently died or came out because the oil is a steady drip now. The car has 120k on it and it's his commuter.
If it's too much of a PITA to do he'll probably ditch the car and drive his Mustang or F150.
Re: 95 Breeze 2.4 rear main seal
[Re: J_BODY]
#1105645
11/01/11 11:30 PM
11/01/11 11:30 PM
Posts: 2,825 Sk. Canada
RemCharger
Sk. Canada
...thinking warranty only paid 2.4 for that job.
uh, yea. Its the 6 cyls that really killed ya.
[Re: RemCharger]
#1105646
11/02/11 02:30 PM
11/02/11 02:30 PM
feets
Senior Management
Senior Management
Irving, TX
I haven't looked at the car. Does the trans need to come down or can you separate it from the engine far enough to do the job?
[Re: feets]
#1105648
11/02/11 04:22 PM
11/02/11 04:22 PM
RemCharger
Sk. Canada
What we used to do (with a lift of course) was get every thing off and loosened up(pull battery and filter etc IIRC) and lower the lift with a rolling table underneath and just shake it out. Lift it up, slap a seal in it(they sometimes just blow right out) set er back down, line the trans up , couple of bolts, and finish installing.
[Re: gtx6970]
#1105649
11/02/11 08:12 PM
11/02/11 08:12 PM
Posts: 2,511 Tampa , Fl
MoparJoe
super gas
super gas
Tampa , Fl
pull the trans or pull the engine. no other way to get to the main seal.
while it's out ck crankshaft end play
I just had one apart for the front and rear crank seals, when I got the timing cover off I found that the crank was walking and letting the timing gear eat into the oil pump, I think spec is around .015" max and this one had around .150" endplay.
[Re: MoparJoe]
#1105650
11/02/11 09:49 PM
11/02/11 09:49 PM
Posts: 1,030 JAX FLA
Curt
JAX FLA
My only thought is make sure it is not the head gasket. Curt
Oh yeah...THAT'S gonna leave a mark!
[Re: Curt]
#1105652
11/03/11 03:08 PM
11/03/11 03:08 PM
RemCharger
Sk. Canada
Just put some Barrs leak stuff in the crankcase.
[Re: feets]
#1105653
11/04/11 12:58 AM
11/04/11 12:58 AM
DaytonaTurbo
Manitoba, Canada
Not a chance of hell. I'm helping a co-worker do one on his vehicle right now. That engine bay is so friggin tight there's no way to do the rear main without either pulling the engine or the trans. I just decided to pull the engine so we could do the water pump, cam seals and timing belt while we're at it. It's a b!tch of a job and if I would have known, I would have just told him to scrap the car!
