Engine Noise Diagnosis *UPDATED WITH VIDEO!*
#110505
08/26/08 09:59 AM
08/26/08 09:59 AM
Posts: 4,389 Kenmore, New York
InViolent
Kenmore, New York
I have some noise on the RH side of my 440 I can't pin down.
It's a fresh engine with maybe 100 miles on it. The RH side has been making noise since the get go...and I blamed it on my Crane Alum Rockers, which are noisy. I swapped in some new Crane Ductiles and the rocker noise is down considerably, but I am still left with what appears to be valve train noise/problem on the RH side.
I have a number of things I am worried about!, but for now, can we talk about collpased lifter sound. How can I verify if I have or dont have a problem lifter or two?
I am running a new Lunati Voodoo 513/533 hyd flat tappet cam with their standard lifters (no anti-pump up style)
Don't want ot pull the intake (6 pack and it actually SEALED for me on the first try!!!) unless needed.
Any help appreciated. I am getting tired of trying to locate the source of this noise!
Re: Engine Noise Diagnosis
[Re: InViolent]
#110511
08/26/08 11:58 AM
08/26/08 11:58 AM
Posts: 75,098 A Banana Republic near you.
JohnRR
I have NOT ruled out exhaust issues...in fact...I found a hole in the weld at the headpipe to flange...I tossed some JB weld in there to give me 5 minutes to see if it would shut the noise up, but it didn't....At first, I was convinced the main noise was coming from the manifold....I am still not sure, but my gut is telling me it sounds more metallic than exhaust leak...
I wouldn't rule out the exh leak yet , a leak at the head sounds very much like a sticky lifter . did you check the manifolds before installing them on a surface plate or a known FLAT surface ?
Don't rule out a lobe going flat , it will keep moving the rocker till it grinds it completely flat , check to see if any pushrods have loosened up .
Also do you have an old valvecover ? cut the top off to help keep the oil in the head area , you'll still make a mess but not as big a mess ...
[Re: stumpy]
#110512
08/26/08 11:58 AM
08/26/08 11:58 AM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Are you sure it's not exhaust related? How about the heat riser in the exhaust manifold rattling?
Also with that cam did you make sure that you have enough valve spring to go avoid coil bind and did you check the clearance with the valve open of the valve spring retainer to the valve guide and seal. You need at least .060 more travel in the valve spring than the actual valve lift and at least the same amount between the guide/seal and the spring retainer. You did check installed height and make sure of closed spring pressure at installed height. Loose springs can be noisy.
[Re: MoparforLife]
#110513
08/26/08 12:53 PM
08/26/08 12:53 PM
InViolent
Kenmore, New York
Right now, I can't rule out anything except the noise is NOT the rockers hitting the valve cover....the sound is similar to "that" sound by the way. I am thinking of making a video of this POS and putting it up so people could listen. I bought a 12$ stethoscope at Napa today, and will give it a try tommorow and update this post.
Now, regarding clearance and spring pressures...All was well with that area. And again, this is definately ISOLATED. The LH side of this engine sounds fine, and RH side is "one or possibly 2" locations. The engine runs/idles fairly smoothly for such a cam profile IMHO, although at times I almost think it's hitting on 7 cyls...Look, I am not sure what to expect from this cam regarding what is "normal and expected" versus "somethings wrong"!!!
I just want to eliminate the simple things first..hopefully before I drop a valve and go back to square one.
[Re: InViolent]
#110516
08/27/08 11:49 PM
08/27/08 11:49 PM
RapidRobert
Just thinking out loud. As I was reading this thread I was thinking throughout that you should replace the lifters on that side(at least) & break the cam in again as my thinking has been influenced by several recent threads which ended up being bad lifters as the culprit but after listening to the audio it sounds different from clicking lifters I have heard in the past & sounds like rocker shaft/rocker arm contact. Keep us posted. Inquiring minds(will) want to know.
[Re: GMP440]
#110517
08/28/08 08:33 AM
08/28/08 08:33 AM
InViolent
Kenmore, New York
Some more info on the RH Exhaust.
This is the correct manifold for a 70-71 e-body. The heat riser assy has been removed, and I installed bolts and nuts to seal the shaft holes. This appears to still be intact. One of the mounting ear locations was cracked but it's the front-most location at the #2 cyl, and it appears to be sealed there.
The headpipes are the repop pipes available, but the car was originally a 383 and when I put the car together 5 or 6 years ago, I bought the "383" head pipes. When I put the 440 in, I called to inquire about new headpipes and was told "Oh, we sell the same pipe for both B and RB engines"...when I tried to bolt the manifold up, I was getting frame/body interference since the 440 sits up a little higher. This was on the RH side only, and required that I use a loose flange spacer and 2 headpipe to manifold gaskets. I originally assumed that this was the source of the leak, but have not been able to determine if this is indeed the issue. Again, I did find a hole in the weld on the headpipe...and JB welded it to see if that would stop the noise. The JB weld is still on there and covering the whole in the video.
I have another manifold coming in, in better shape than this one...so I intend to swap out manifolds anyway and get this flange/headpipe looked at by a quality muffler shop.
Any more comments?
I appreciate the thoughts.
[Re: InViolent]
#110518
08/28/08 10:47 AM
08/28/08 10:47 AM
Posts: 1,663 E.Amherst, NY
69RR
E.Amherst, NY
Sounds to me like an exhaust manifold issue. Have you pulled each plug wire from the right bank? It may help eliminate that exhaust as part of the problem. Just my Hope you solve it.
Dean
Got my hands on the wheel, foot to the pedal, gonna drive this car till the tires turn to metal - gonna sleep when I'm dead and laugh at the devil..
[Re: InViolent]
#110522
08/28/08 11:36 AM
08/28/08 11:36 AM
Posts: 6,780 Alabama
Mopar-Al
Alabama
Mr Gasket Ultra-Seal gaskets are used.
The head pipe to manifold gaskets are typical Fel-Pro...but like I said...I am running a SPACER to get the damn pipe off the underbody....I took the spacer and RTV'd the two gaskets to it when I installed this engine last summer.
I had those same gaskets on my 440-6 mine made the same noise or close to it. I had to tighten them up over and over. Then someone said to run my manifolds without gaskets, that they came that way from the factory.
I wasn't sure if that was true or not, but I pulled mine off and went without gaskets on the pass side. No more noise.
Yr one has a seperate part number for the 440-6 head pipes. Mine went on without any problems. They cost like 106 each.
In 70 there is a different part number for one of the manifolds. I got mine off of a 70 challenger six pack. The flange had a different twist to it rather than the b body 69 stuff.
[Re: Mopar-Al]
#110524
08/28/08 11:43 AM
08/28/08 11:43 AM
InViolent
Kenmore, New York
Man...it seems counter-intuitive to think I could get a better seal without a gasket...what about Copper gaskets? Are they saying the Mr Gasket or Fel Pro gaskets are tearing or getting crushed or something?
The engine moves around quite a bit at Idle.....with a little RPM's it smooths out. But yeah, those rubber mounts may not last long.
