line pressure
#1104770
10/31/11 02:52 PM
10/31/11 02:52 PM
Posts: 4,648 aotearoa
rebel
aotearoa
i got my beast fired up last night & all went well. added the juice to the trans as reqd. had fitted a guage to check the line pressure & it don't read anything. what the....?. am i connect to the correct port? on the right hand side of the trans i'm hooked into the center plug port. according to the trans book i have this as the line pressure plug but its not reading anything. hope my guage aint puckerood!.
Re: line pressure
[Re: rebel]
#1104771
10/31/11 02:58 PM
10/31/11 02:58 PM
Posts: 26,032 Rio Linda, CA
John_Kunkel
Rio Linda, CA
You won't have pressure at the center port until it's in a forward gear...the exception being some valve bodies that don't pressurize the accumulator in which case you won't be able to get a pressure reading there in any gear.
Re: line pressure
[Re: John_Kunkel]
#1104773
11/01/11 12:38 AM
11/01/11 12:38 AM
rebel
aotearoa
i have a A&A LBA brake with safe Neutral, do you know if that VB pumps up the pressure?
Re: line pressure
[Re: rickraw]
#1104774
11/01/11 05:26 AM
11/01/11 05:26 AM
rebel
aotearoa
u will see line pressure in 1st, 2nd & 3rd.
ran the engine & trans up again tonite. no movement of my guage. i really want to know my line pressure on a fresh trans for comparision later. i guess it's check my guage first.
Re: line pressure
[Re: rebel]
#1104775
11/01/11 04:24 PM
11/01/11 04:24 PM
John_Kunkel
Rio Linda, CA
The LBA valve body blocks the accumulator so there is no pressure at the center port ever.
You can get a pressure reading at the front (kickdown servo) test port when the trans is in 3rd gear or the rear servo port when the trans is in 1st gear.
Re: line pressure
[Re: John_Kunkel]
#1104776
11/02/11 03:06 AM
11/02/11 03:06 AM
rebel
aotearoa
cheers john this is the info i needed. thank you. EDIT. swapped locations tonite & redid test. all good now, i have 140psi at idle in 1st. will test before adjusting.
