what's acceptable for wrist pin clearance on a floating #1104321
10/30/11 09:18 PM
10/30/11 09:18 PM
Ontario,Canada
brads70 Offline OP
brads70  Offline OP
Ontario,Canada
Hi all!
I just bought a 451" stroker kit and when I measured everything up I got .0018" on one rod and the rest were around .0015" The pin rocks in the rod. Sure doesn't give me a warm fuzzy feeling? I'd me more comfortable with .0005" to .0008" max? That and the grinding on the sides to " balance" the rods? Some are ground right into the shoulder on the rod bolt. My good buddy that builds stock car engines for a living looked at it and just shook him head. This is gonna be a street engine with a hyd roller cam.
Re: what's acceptable for wrist pin clearance on a floating [Re: brads70] #1104322
10/30/11 09:21 PM
10/30/11 09:21 PM
Millinocket, Maine
JonC Offline
JonC  Offline
Millinocket, Maine
I'm no expert for sure, but I don't see a really good place to grind for balance on those rods. That's probably the best spot. But I think I would take a little off both sides and not a lot on one side.
Re: what's acceptable for wrist pin clearance on a floating [Re: brads70] #1104323
10/30/11 09:25 PM
10/30/11 09:25 PM
No good. Call em up & request a return authorization.
Re: what's acceptable for wrist pin clearance on a floating [Re: RapidRobert] #1104324
10/30/11 09:47 PM
10/30/11 09:47 PM
Ontario,Canada
brads70 Offline OP
brads70  Offline OP
Ontario,Canada
Ya that's the plan, mailing them back tomorrow. I gotta eat the postage , but better that than a new set of rods.
Thanks all for the replies!
Re: what's acceptable for wrist pin clearance on a floating [Re: brads70] #1104325
10/31/11 02:37 AM
10/31/11 02:37 AM
Brad who was the source of those rods? I'm in the market for some 7.1's and dont wanna to get burnt
Re: what's acceptable for wrist pin clearance on a floating [Re: brads70] #1104326
10/31/11 03:18 AM
10/31/11 03:18 AM
The needed (proper to live) wrist pin clearances will vary depending on the application, that being said I don't know any machine shop or racers that use .0015 wrist pin clearances to the pistons or rods I would much rather see .0008 to .0012 than .0005 I have seen wrist pins galled up due to to little clearances ,never saw a wrist pin galled up due to excessive clearances, bent yes, but not galled up When it comes to clearances in a Hi Po motor a little bit looser is usually way better than a tiny bit to tight
Re: what's acceptable for wrist pin clearance on a floating [Re: brads70] #1104327
10/31/11 06:26 AM
10/31/11 06:26 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Well that's good they are gonna take them back! Eating postage in the end would be much cheaper i would presume! Great catch and atleast they are making it right!
Mopar Performance
Re: what's acceptable for wrist pin clearance on a floating [Re: RapidRobert] #1104328
10/31/11 08:16 AM
10/31/11 08:16 AM
Ontario,Canada
brads70 Offline OP
brads70  Offline OP
Ontario,Canada
I don't want to " throw them under the bus" as they said they will replace them. I figure everyone screws up now and then. The difference is admiting it and making it right. That seperates the men from the boys!
Off to the post office today....
Re: what's acceptable for wrist pin clearance on a floating [Re: brads70] #1104329
10/31/11 10:16 AM
10/31/11 10:16 AM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
There is a big difference in " screwing up every now and then" and just plain horrible workmanship. They performed the latter on that job. Not only that, but if they had a clue, they would NEVER balance a rod like that, putting hundreds of stress risers right down the side of a bolt hole on a connecting rod. Thats work of a 10 year old. They simply didnt care, hoped you wouldnt notice ( or knpow the difference) or just hired a 10 year old in their shop. Ok, so they dont know how to balance, THEN they decide to send rod pins out with almost DOUBLE the accepted and needed clearance? Why you would protect them I dont know, but thats your call. I'd get my money back and deal with someone who actually knows what they are doing, unless of course, " best price" was what this purchase was about.
Good luck on the next set.
RIP Monte Smith
Re: what's acceptable for wrist pin clearance on a floating [Re: CompWedgeEngines] #1104330
11/28/11 09:54 PM
11/28/11 09:54 PM
Ontario,Canada
brads70 Offline OP
brads70  Offline OP
Ontario,Canada
Well I got my new replacement rods. Muscle Motors came through in the end! I'll fit the pins myself as they don't quite fit the new rods. I weighted them and they are all within 1.5 grams , so I have no idea why the ground the sides like that?
Re: what's acceptable for wrist pin clearance on a floating [Re: brads70] #1104331
11/28/11 11:00 PM
11/28/11 11:00 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
I wouldn't grind on the sides of the caps like that to balance them. My machinist is balancing a set of Manley I-beam rods for me and I ran a simplified Hemi rod under tension. I found the cap area at the parting line and 90 degrees to that on the center of the cap to have high stress areas. I found similar results in a technical paper online on rod stresses.
Floyd Lippencott IV
Re: what's acceptable for wrist pin clearance on a floating [Re: brads70] #1104332
11/29/11 12:27 AM
11/29/11 12:27 AM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
FSMs always called for "light thumb push" at room temp., and that's always worked for me!
Rick
Re: what's acceptable for wrist pin clearance on a floating [Re: Cab_Burge] #1104333
11/29/11 01:22 AM
11/29/11 01:22 AM
Florida STAYcation
BeEtLeJuIcE ! Online penguin-006
The village idiot's idiot
BeEtLeJuIcE !  Online Penguin-006
Florida STAYcation
I would much rather see .0008 to .0012 than .0005 I have seen wrist pins galled up due to to little clearances ,never saw a wrist pin galled up due to excessive clearances, bent yes, but not galled up .....
There was a post(with pics ) here 4 or 5 months ago with the bushing BEAT OUT of the small end ....probably due to Xcess clearance.
I have put together a couple of floaters ... NOTHING looser than .0009.
Re: what's acceptable for wrist pin clearance on a floating [Re: Rick_Ehrenberg] #1104334
11/29/11 01:29 AM
11/29/11 01:29 AM
Mississippi
lahatte Offline
lahatte  Offline
Mississippi
Rick, is that thumb push with oil or without?
Re: what's acceptable for wrist pin clearance on a floating [Re: brads70] #1104335
11/29/11 02:49 AM
11/29/11 02:49 AM
Delray beach, Florida
P
Performance Only Offline
P
glad to hear you got that taken care of.
how does the weight of the new rods compare to the ones you sent back?
machine shop owner and engine builder
Re: what's acceptable for wrist pin clearance on a floating [Re: Performance Only] #1104336
11/29/11 06:00 PM
11/29/11 06:00 PM
Ontario,Canada
brads70 Offline OP
brads70  Offline OP
Ontario,Canada
They were within 2 grams of the old ones. And they are all within/less than 2 grams now , so thats good enough for me, no need to do anything except fit the wrist pins IMO....and check the big end for size.
Re: what's acceptable for wrist pin clearance on a floating [Re: brads70] #1104337
11/29/11 06:24 PM
11/29/11 06:24 PM
Northern California
lilcuda Offline
lilcuda  Offline
Northern California
I wouldn't let MM work on my lawnmower engine. Long story...
Re: what's acceptable for wrist pin clearance on a floating [Re: lahatte] #1104338
11/29/11 06:28 PM
11/29/11 06:28 PM
Northern California
lilcuda Offline
lilcuda  Offline
Northern California
And who's thumb are we talking about? That kind of "spec" is great for a backyard guy with stock parts, but in a performance application you have to measure the clearance with the proper equipment.
Re: what's acceptable for wrist pin clearance on a floating [Re: lilcuda] #1104339
11/29/11 09:33 PM
11/29/11 09:33 PM
Florida STAYcation
Florida STAYcation
So right ...
