Hi,
Im in the process of the rebuilding of the individual components of my 72 Chrysler 727 torqueflite.
I have installed new clutches and plates in the front clutch drum. the factory allowed tolerance between the pressure plate and snap ring is between .088 to .145 with a 4 disc setup on a 440 4 bbl. My best measurement with me pushing the snap ring down is .158 to .168 leaving it alone and finding the lowest spot under the "wave" as the books say.
I've replaced the 9 factory clutch piston springs with new OEM ones and a new retainer, new seals on the piston and the piston is bottomed out in the bore as instructed in the factory manual and the handbook, as well, I have installed 4 new clutch discs and metal plates in and put the original pressure plate & snap ring back in.
i have read about a thicker snap rings, is this a viable option? THis is my first trans rebuild, i'm super confident since I'm using the A 727 Torqueflite rebuild handbook available everywhere online and in stores, and would like to move on to the rear clutch pack and ut this to bed. I've come across no issues whatsoever so far.
ANY help would be appreciated.
Best,
Derek
