torque convertor and auto trans #1103762
10/29/11 03:36 PM
10/29/11 03:36 PM
Winnipeg,Manitoba
cudablues Offline OP
Winnipeg,Manitoba
Wondering what stall to use on this motor.585 HP.640 torque at 3900.Will be mostly street driven.Thought i read somewhere,one thought is 500 RPM below the RPM where it makes peak torque.Seems a little high for the street.Also what a good auto trans for it.
Re: torque convertor and auto trans [Re: cudablues] #1103763
10/30/11 09:19 AM
10/30/11 09:19 AM
Winnipeg,Manitoba
Winnipeg,Manitoba
bump
Re: torque convertor and auto trans [Re: cudablues] #1103764
10/30/11 09:50 AM
10/30/11 09:50 AM
ill
dennismopar73 Offline
ill
4000-4500 9 1/2" j type , good cooler deep pan
Re: torque convertor and auto trans [Re: dennismopar73] #1103765
10/30/11 10:45 AM
10/30/11 10:45 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Best thing to do is call the converter company you plan to use and let them tell you what you need. I am using a Luppo Dynamic 9.5 converter that flashes about 4200 but drives like a normal converter. I make about 600 flywheel hp and about 540 to the wheels. Ron
