My car, the crop duster.
#1103547
10/29/11 01:56 AM
10/29/11 01:56 AM
Posts: 2,309 Tomorrow.
Damned67
Tomorrow.
Hi All, I'm sitting somewhere between freaking out and 'cool'. Last time I had the car out on the road (other than today), I noticed it smoking a lovely shade of blue-grey when coming to a set of lights. Trip before that was out to the drag strip, and there were no signs of smoke at all (that I noticed). The short drive when I first noticed the smoke was around the same time as I replaced the PCV. I lashed the valves the other day and noticed the lovely blue-grey smoke at idle, slowly filling the driveway. Today, I replaced a cracked spark plug and put a fuel filter in the PCV line, then took the car for a short (10min) run. It was like a crop duster to begin with, leaving a long trail of smoke down the street. Didn;t really seem to notice a huge difference in smoke output under different conditions (cruise, idle, accel etc), but on one occasion noticed a puff on deceleration. Anyway, long story short, by the time I parked it back in the driveway, it didn't really seem to be smoking at all? Engine is a low mileage 505" RB (<1000 miles), but sits for long periods. Fuel, although I put a few fresh gallons in the other day, would be over 12 months old.
Due to the smoking at idle, I'm leaning towards either oil through the PCV or sucking oil through an intake gasket leak? Anyway, I plan on having another drive and a better look tomorrow, but assuming it's still smoking, what should I look to try for for a better diagnosis?
Cheers!
Re: My car, the crop duster.
[Re: Damned67]
#1103548
10/29/11 02:17 AM
10/29/11 02:17 AM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
When I had an oil burning/engine smoking issue with the 493 in my Charger, I looked at every possible angle, then discovered that the rings were worn out and the cylinders were glazed. The fix was to hone the cylinders and put in new rings. This is probably NOT what you want to hear. Before giving up and pulling the motor, consider the following: The PCV hose should run to the base of the carb. The valve cover NEEDS to have a baffle under the PCV valve as well. The non PCV valve cover needs to have some sort of vent to it be it a breather or a can with a hose to the air cleaner. The Intake mounting bolts need some sort of sealant, as they are openly threaded into the lifter valley. The valley pan may not be sealing, allowing oil to be sucked into the cylinders and burned. You can determine this by pulling the spark plugs and looking at the porceline tips. Discoloration on ONE side indicates a "spray" of sorts is occurring. Have a friend follow you to determine if the smoke is coming from the tailpipes OR swirling from under the car. At one time, all my oil pan bolts were finger tight, allowing oil to seep through and sling against the headers causing some smoke. Another time, the speedometer pinion housing had a bad O ring and ATF seeped against the exhaust, causing smoke. Hopefully your is a case of external smoke, saving you the time of a rebuild. I referred to my Charger as the "James Bond smokescreen" until I fixed it. Now the only smoke is from the fat 850 carb and the Nitto tires!
[Re: Damned67]
#1103554
10/30/11 09:56 AM
10/30/11 09:56 AM
Posts: 2,177 ill
dennismopar73
ill
just a thought,, car is running rich on gas, so it 'gasses' the rings, basically washes them out , so they get no lube, then the heat up, take the tension out, and here come the smoke and oil consumption. oooo could hope it's the valve stem seals on the heads??
[Re: RapidRobert]
#1103557
10/30/11 10:13 PM
10/30/11 10:13 PM
Damned67
Tomorrow.
At least it wasn't crop dusting today as I drove.
What did you change on it
Nothing, but the day before I put a fuel filter in the PCV line (got that tip from AndyF or Streetwise on here). I'm thinking (hoping) that the previous days run, after I'd just put in the filter, that it was still burning residual oil.
Although, the smoke that accompanied yesterdays initial start up, I would think might be associated with valve seals?
I'm going to toss some fresh plugs in and see what happens (and then have a better chance of reading them too).
Cheers
[Re: dennismopar73]
#1103559
10/31/11 12:47 AM
10/31/11 12:47 AM
Damned67
Tomorrow.
still hopping the issue is at the valve springs seals ,?
So am I! I'm going to toss some new plugs in on the weekend, and readdress carb tuning. Will keep updating. Cheers
[Re: dennismopar73]
#1103560
10/31/11 12:49 AM
10/31/11 12:49 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
The filter in the PCV line captures oil, blowby isn't oil, it's combustion gases.. The reason you get oil in the PCV system is having the PCV valve positioned where there is oil spray, usually oil intended to lube the valve gear... Well designed baffles in the valve cover are typically the long term fix...
[Re: 1_WILD_RT]
#1103561
10/31/11 01:19 AM
10/31/11 01:19 AM
Posts: 2,177 ill
dennismopar73
ill
sorry I'm confused? normal crankcase venting is what pressure that is develop from the piston rotating up and down , 'blow by' is what escapes past the rings after compression, that is the gasses you so called. nothing says you have to have a pcv valve ! as long as you have a way for the pressures to escape out of the motor, A pcv valve system is 'dirty'by it nature, and the motor re-burns oil and gasses that has been previously burned , hense allot of guy use evac tubes, helps keep motor burning clean air! An engine that is set up right doesn't have allot of blow by causing more than normal oil consumption to occur passed the pcv and the baffles,, any engine that has higher miles , run hot, will have the issues of oil consumption and excessive oil past the pcv valve other than that we are talking the same stuff
[Re: dennismopar73]
#1103562
10/31/11 01:36 AM
10/31/11 01:36 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
My point is the engine may be 100% healthy, fact is with less than 1000 miles on the engine it should be 100% healthy though with to much fuel washing the oil out of the rings there is no guaranty that it is... But most aftermarket valve covers have no baffling so oil consumption becomes a serious issue... Yes PCV systems by nature are sending crankcase vapors through the intake to be burned, but if the vapors are properly baffled & allow the oil to fall out of suspension then oil burning can be virtually eliminated.. Evac systems are fine in a race application but you need more RPM's for them to be effective so it's better suited to a race application... plus if the exhaust system has any backpressure the crankcase will be pressurized.. There are guys who insist the old road draft tube is better for the engine but for that system to be effective you need to have the vehicle moving 25 mph or more, the road & the bottom of the car are gonna be covered with oil.... Sorry for a normal street driven car a well designed & executed closed PCV system is the best option..
